Hello everyone, I have a lisp which gets the coordinates of a line and also gets its color. The problem is it gets the color in index not the true color, so for example for the blue color it gets "5"
instead of "0,0,255" thats what i want
The lisp is attached. Can anyone help with that ?
Thank you
LLC.lsp
sorry i am new to autolisp, where should i put the codes in the link you shared ?
(defun c:LLC ( / js dxf_cod mod_sel n lremov str_sep oldim ename X1 Y1 X2 Y2 col tmp f_open)
  (princ "\nSelect a model object to make filter: ")
  (while
    (null
      (setq js
        (ssget "_+.:E:S"
          (list
            '(0 . "LINE")
            (cons 67 (if (eq (getvar "CVPORT") 1) 1 0))
            (cons 410 (if (eq (getvar "CVPORT") 1) (getvar "CTAB") "Model"))
    (princ "\nIsn't a Line!")
  (vl-load-com)
  (setq dxf_cod (entget (ssname js 0)))
  (foreach m (foreach n dxf_cod (if (not (member (car n) '(0 67 410 8 6 48))) (setq lremov (cons (car n) lremov))))
    (setq dxf_cod (vl-remove (assoc m dxf_cod) dxf_cod))
  (initget "Single All Manual")
  (if (eq (setq mod_sel (getkword "\nApply filter to ? [Single/All/Manual]<Manual>: ")) "Single")
    (setq n -1)
    (if (eq mod_sel "All")
        (setq js (ssget "_X" dxf_cod) n -1)
        (setq js (ssget dxf_cod) n -1)
  (setq
    tmp (vl-filename-mktemp "tmp.csv")
    f_open (open tmp "w")
    str_sep ";"
    oldim (getvar "dimzin")
  (setvar "dimzin" 0)
  (write-line (strcat "X1" str_sep "Y1" str_sep "X2" str_sep "Y2" str_sep "Color") f_open)
  (repeat (sslength js)
    (setq
      ename (ssname js (setq n (1+ n)))
      dxf_cod (entget ename)
      X1 (cadr (assoc 10 dxf_cod))
      Y1 (caddr (assoc 10 dxf_cod))
      X2 (cadr (assoc 11 dxf_cod))
      Y2 (caddr (assoc 11 dxf_cod))
    (write-line
      (strcat
        (rtos X1 2 3)
        str_sep
        (rtos Y1 2 3)
        str_sep
        (rtos X2 2 3)
        str_sep
        (rtos Y2 2 3)
        str_sep
        (if (assoc 420 dxf_cod)
            (setq col (LM:True->RGB (cdr (assoc 420 dxf_cod))))
            (strcat (itoa (car col)) "," (itoa (cadr col)) "," (itoa (caddr col)))
            (cond
              ((= (assoc 62 dxf_cod) 256)
                "by layer"
              ((= (assoc 62 dxf_cod) 0)
                "by block"
              (t
                (setq col (LM:ACI->RGB (cdr (assoc 62 dxf_cod))))
            ) ;end of cond
          ) ;end of progn
        ) ;end of if
      f_open
  (close f_open)
  (startapp "notepad" tmp)
  (setvar "dimzin" oldim)
  (prin1)
;; True -> RGB  -  Lee Mac
;; Args: c - [int] True Colour
(defun LM:True->RGB ( c )
  (mapcar '(lambda ( x ) (lsh (lsh (fix c) x) -24)) '(8 16 24))
;; ACI -> RGB  -  Lee Mac
;; Args: c - [int] ACI (AutoCAD Colour Index) Colour (1<=c<=255)
(defun LM:ACI->RGB ( c / o r )
    (if (setq o (vla-getinterfaceobject (LM:acapp) (strcat "autocad.accmcolor." (substr (getvar 'acadver) 1 2))))
            (setq r
                (vl-catch-all-apply
                   '(lambda ( )
                        (vla-put-colorindex o c)
                        (list (vla-get-red o) (vla-get-green o) (vla-get-blue o))
            (vlax-release-object o)
            (if (vl-catch-all-error-p r)
                (prompt (strcat "\nError: " (vl-catch-all-error-message r)))
                r
;; Application Object  -  Lee Mac
;; Returns the VLA Application Object
(defun LM:acapp nil
    (eval (list 'defun 'LM:acapp 'nil (vlax-get-acad-object)))
    (LM:acapp)
like this, this code is not tested
Edited by exceed
thank you for your reply, it works well some times, but other times is does not work and goves this error
"Error: ActiveX Server returned an error: Parameter not optional; error: bad argument type: fixnump: nil"
i will attach a file that things are not working with me.
i guess this problem happens with the line color is not index, so can there be something general that can consider all color types and change all to true colors ?
Can that be fixed ?Drawing2.dwg
Edited by asdfgh
try this
(defun c:LLC ( / js dxf_cod mod_sel n lremov str_sep oldim ename X1 Y1 X2 Y2 col tmp f_open thatlayer layercol thatlayertruecolor layerred layergreen layerblue )
  (while
    (null
      (setq js
        (ssget "_+.:E:S"
          (list
            '(0 . "LINE")
  (vl-load-com)
    (setq n -1)
  (setq
    str_sep ";"
  (setvar "dimzin" 0)
    (setq
    (write-line
      (strcat
        (rtos X1 2 3)
        str_sep
        (rtos Y1 2 3)
        str_sep
        (rtos X2 2 3)
        str_sep
        (rtos Y2 2 3)
        str_sep
            (if (assoc 62 dxf_cod)
                (cond
                  ((= (cdr (assoc 62 dxf_cod)) 0)
                    "by block"
                  ((and (> (cdr (assoc 62 dxf_cod)) 0) (< (cdr (assoc 62 dxf_cod)) 256))
                (setq col (vlax-get-property (vlax-ename->vla-object ename) 'color))
                (cond
                  ((= col 256)
                    (setq thatlayer (vlax-get-property (vlax-ename->vla-object ename) 'layer))
                    (setq thatlayertruecolor (vlax-get-property (vla-Item (vla-get-Layers (vla-get-ActiveDocument (vlax-get-Acad-Object))) thatlayer) 'truecolor))
                    (setq layerred (vlax-get-property thatlayertruecolor 'red))
                    (setq layergreen (vlax-get-property thatlayertruecolor 'green))
                    (setq layerblue (vlax-get-property thatlayertruecolor 'blue))
                    (setq layercol (list layerred layergreen layerblue))
                    (strcat "by layer ( " (itoa (car layercol)) "," (itoa (cadr layercol)) "," (itoa (caddr layercol)) " )")
                  ((= col 0)
                    "by block"
                );end of cond
              );end of progn
            ) ;end of if
          ) ;end of progn
        ) ;end of if
      f_open
  (close f_open)
  (prin1)
            (setq r
                (vl-catch-all-apply
                   '(lambda ( )
                r
(defun LM:acapp nil
    (LM:acapp)
fix, in case of 'If the color is by layer, and the color of the layer is true color'
below is old version
(defun c:LLC ( / js dxf_cod mod_sel n lremov str_sep oldim ename X1 Y1 X2 Y2 col tmp f_open thatlayer layercol)
  (while
    (null
      (setq js
        (ssget "_+.:E:S"
          (list
            '(0 . "LINE")
  (vl-load-com)
    (setq n -1)
  (setq
    str_sep ";"
  (setvar "dimzin" 0)
    (setq
    (write-line
      (strcat
        (rtos X1 2 3)
        str_sep
        (rtos Y1 2 3)
        str_sep
        (rtos X2 2 3)
        str_sep
        (rtos Y2 2 3)
        str_sep
                (cond
                    "by block"
                (cond
                  ((= col 256)
                    "by layer"
                    (setq thatlayer (tblsearch "layer" (vlax-get-property (vlax-ename->vla-object ename) 'layer)))
                    (if (assoc 420 thatlayer)
                        (setq layercol (LM:True->RGB (cdr (assoc 420 thatlayer))))
                        (if (assoc 62 thatlayer)
                            (cond
                              ((= (cdr (assoc 62 thatlayer)) 0)
                                "by block"
                              ((and (> (cdr (assoc 62 thatlayer)) 0) (< (cdr (assoc 62 thatlayer)) 256))
                                (setq layercol (LM:ACI->RGB (cdr (assoc 62 thatlayer))))
                            );end of cond
                          );end of progn
                            "N/A"
                        );end of if
                      );end of progn
                    );end of if
                  ((= col 0)
                    "by block"
                );end of cond
              );end of progn
            ) ;end of if
          ) ;end of progn
        ) ;end of if
      f_open
  (close f_open)
  (prin1)
            (setq r
                (vl-catch-all-apply
                   '(lambda ( )
                r
(defun LM:acapp nil
    (LM:acapp)
Edited by exceed
