mousho Posted June 9, 2022 Share Posted June 9, 2022 Hi friends i write this lisp and need help to change it the lisp make a table of character map with /u+0000 there is anyway to use the "alt"+0000 instead? didnt find enywere the use of "alt" with lisp text table 2.lsp Quote Link to comment Share on other sites More sharing options...
mhupp Posted June 9, 2022 Share Posted June 9, 2022 (edited) Isn't that the same thing? never mind I see 32 = 2 when its suppose to be space. Creates a txt file in my documents. might help? (defun C:ASCII ( / chk out ct code dec oct hex ) (initget "Yes") (setq chk (getkword "\nWriting to ASCII.TXT, continue? <Y>: ")) (if (or (= chk "Yes")(= chk nil)) (progn (setq out (open (strcat (getenv "userprofile") "\\Documents\\ascii.txt") "w") chk 1 code 0 ct 0) (princ "\n \n CHAR DEC OCT HEX \n") (princ "\n \n CHAR DEC OCT HEX \n" out) (while chk (setq dec (strcat " " (itoa code)) oct (base 8 code) hex (base 16 code)) (setq dec (substr dec (- (strlen dec) 2) 3)) (if (< (strlen oct) 3)(setq oct (strcat "0" oct))) (princ (strcat "\n " (chr code) " " dec " " oct " " hex ) ) (princ (strcat "\n " (chr code) " " dec " " oct " " hex ) out) (cond ((= code 255)(setq chk nil)) ((= ct 20) (setq xxx (getstring "\n \nPress 'X' to eXit or any key to continue: ")) (if (= (strcase xxx) "X") (setq chk nil) (progn (setq ct 0) (princ "\n \n CHAR DEC OCT HEX \n") ) ) ) ) (setq ct (1+ ct) code (1+ code)) ) (close out) (setq out nil) ) ) (princ) ) ; BASE converts from a decimal integer to a string in another base. (defun BASE ( bas int / ret yyy zot ) (defun zot ( i1 i2 / xxx ) (if (> (setq xxx (rem i2 i1)) 9) (chr (+ 55 xxx)) (itoa xxx) ) ) (setq ret (zot bas int) yyy (/ int bas)) (while (>= yyy bas) (setq ret (strcat (zot bas yyy) ret)) (setq yyy (/ yyy bas)) ) (strcat (zot bas yyy) ret) ) Edited June 9, 2022 by mhupp Quote Link to comment Share on other sites More sharing options...
mhupp Posted June 9, 2022 Share Posted June 9, 2022 (edited) Fixed it with function chr ;;----------------------------------------------------------------------------;; ;; used to lookup character ascii number (defun C:text_table (/ vars vals base i c n H S tx base_n) (setq vars '(snapmode osmode cmdecho ATTDIA ATTREQ LUPREC) ;list of variables vals (mapcar 'getvar vars) ;store old values ) (mapcar 'setvar vars '(0 0 0 0 1 0)) ;set new values (setq base (getpoint "\nEnter Starting Point :") i 0 c 0 n (/ (getvar 'textsize) 8) H (getvar 'textsize) S (getvar 'textstyle) ) (while (< i 1000) (setq tx (strcat (AT:NumFix (itoa i) 4) " = " (chr i)) base_n (list (+ (car base) (* (fix (* (/ c 25) n)) 100)) (- (cadr base) (* 20 (* c n)))) ) (entmake (list '(0 . "TEXT") (cons 8 (getvar 'clayer)) (cons 10 base_n) (cons 40 H) (cons 1 tx) (cons 7 S) ) ) (setq i (1+ i)) (setq c (1+ c)) (if (eq c 25) ;simple counter to step over (progn (setq base (polar base 0 (* 10 (getvar 'textsize)))) (setq c 0) ) ) ) (mapcar 'setvar vars vals) ;restore old values (princ) ) (defun AT:NumFix (s n) ;; Fix number string with leading zeros ;; s - Number string to fix ;; n - Number of characters for final string ;; Alan J. Thompson, 10.29.09 ;; (AT:NumFix i 3) i= 1 = 001 (if (< (strlen s) n) (AT:NumFix (strcat "0" s) n) s ) ) Edited February 10, 2023 by mhupp code updated exceed's changes Quote Link to comment Share on other sites More sharing options...
mousho Posted June 12, 2022 Author Share Posted June 12, 2022 On 6/9/2022 at 4:28 PM, mhupp said: Fixed it with function chr (defun C:text_table (/ vars vals base i c tx base_n) (setq vars '(snapmode osmode cmdecho ATTDIA ATTREQ LUPREC) ;list of variables vals (mapcar 'getvar vars) ;store old values ) (mapcar 'setvar vars '(0 0 0 0 1 0)) ;set new values (setq base (getpoint "\nEnter Starting Point :") i 0 c 0 ) (while (< i 1000) (setq tx (strcat (AT:NumFix (itoa i) 4) " = " (chr i)) base_n (polar base (* pi 1.5) (* 20 i)) base_n (list (+ (car base) (* (fix (/ i 25)) 100)) (- (cadr base) (* 20 i))) ) (entmake (list '(0 . "TEXT") (cons 10 base_n) (cons 11 base_n) '(40 . 8.0) (cons 1 tx) '(71 . 0) '(72 . 1) '(70 . 0) ) ) (setq i (1+ i)) (setq c (1+ c)) (if (eq c 25) ;simple counter to step over (progn (setq base (polar base (* PI 0.5) 500)) (setq c 0) ) ) ) (mapcar 'setvar vars vals) ;restore old values (princ) ) (defun AT:NumFix (s n) ;; Fix number string with leading zeros ;; s - Number string to fix ;; n - Number of characters for final string ;; Alan J. Thompson, 10.29.09 (if (< (strlen s) n) (AT:NumFix (strcat "0" s) n) s ) ) THX but i get error "Invalid field type 70 in (entmake)." Quote Link to comment Share on other sites More sharing options...
exceed Posted June 12, 2022 Share Posted June 12, 2022 35 minutes ago, mousho said: THX but i get error "Invalid field type 70 in (entmake)." you can solve that by deleting '(70 . 0) line I tested it (defun C:text_table (/ vars vals base i c tx base_n) (setq vars '(snapmode osmode cmdecho ATTDIA ATTREQ LUPREC) ;list of variables vals (mapcar 'getvar vars) ;store old values ) (mapcar 'setvar vars '(0 0 0 0 1 0)) ;set new values (setq base (getpoint "\nEnter Starting Point :") i 0 c 0 ) (while (< i 1000) (setq tx (strcat (AT:NumFix (itoa i) 4) " = " (chr i)) base_n (polar base (* pi 1.5) (* 20 i)) base_n (list (+ (car base) (* (fix (/ i 25)) 100)) (- (cadr base) (* 20 i))) ) (entmake (list '(0 . "TEXT") (cons 10 base_n) (cons 11 base_n) '(40 . 8.0) (cons 1 tx) '(71 . 0) '(72 . 1) ) ) (setq i (1+ i)) (setq c (1+ c)) (if (eq c 25) ;simple counter to step over (progn (setq base (polar base (* PI 0.5) 500)) (setq c 0) ) ) ) (mapcar 'setvar vars vals) ;restore old values (princ) ) (defun AT:NumFix (s n) ;; Fix number string with leading zeros ;; s - Number string to fix ;; n - Number of characters for final string ;; Alan J. Thompson, 10.29.09 (if (< (strlen s) n) (AT:NumFix (strcat "0" s) n) s ) ) 1 Quote Link to comment Share on other sites More sharing options...
mousho Posted June 12, 2022 Author Share Posted June 12, 2022 1 hour ago, exceed said: you can solve that by deleting '(70 . 0) line I tested it (defun C:text_table (/ vars vals base i c tx base_n) (setq vars '(snapmode osmode cmdecho ATTDIA ATTREQ LUPREC) ;list of variables vals (mapcar 'getvar vars) ;store old values ) (mapcar 'setvar vars '(0 0 0 0 1 0)) ;set new values (setq base (getpoint "\nEnter Starting Point :") i 0 c 0 ) (while (< i 1000) (setq tx (strcat (AT:NumFix (itoa i) 4) " = " (chr i)) base_n (polar base (* pi 1.5) (* 20 i)) base_n (list (+ (car base) (* (fix (/ i 25)) 100)) (- (cadr base) (* 20 i))) ) (entmake (list '(0 . "TEXT") (cons 10 base_n) (cons 11 base_n) '(40 . 8.0) (cons 1 tx) '(71 . 0) '(72 . 1) ) ) (setq i (1+ i)) (setq c (1+ c)) (if (eq c 25) ;simple counter to step over (progn (setq base (polar base (* PI 0.5) 500)) (setq c 0) ) ) ) (mapcar 'setvar vars vals) ;restore old values (princ) ) (defun AT:NumFix (s n) ;; Fix number string with leading zeros ;; s - Number string to fix ;; n - Number of characters for final string ;; Alan J. Thompson, 10.29.09 (if (< (strlen s) n) (AT:NumFix (strcat "0" s) n) s ) ) Perfect how can i change it that it work on the current text style? Quote Link to comment Share on other sites More sharing options...
exceed Posted June 12, 2022 Share Posted June 12, 2022 14 minutes ago, mousho said: Perfect how can i change it that it work on the current text style? (defun C:text_table (/ vars vals base i c tx base_n currentlayer currenttextstyle currenttextsize somenumber) (setq vars '(snapmode osmode cmdecho ATTDIA ATTREQ LUPREC) ;list of variables vals (mapcar 'getvar vars) ;store old values ) (mapcar 'setvar vars '(0 0 0 0 1 0)) ;set new values (setq base (getpoint "\nEnter Starting Point :") i 0 c 0 ) (setq currentlayer (getvar 'clayer)) ;edited line (setq currenttextstyle (getvar 'textstyle)) ;edited line (setq currenttextsize (getvar 'textsize)) ;edited line (setq somenumber (/ currenttextsize 8)) (while (< i 1000) (setq tx (strcat (AT:NumFix (itoa i) 4) " = " (chr i)) base_n (polar base (* pi 1.5) (* 20 (* i somenumber))) base_n (list (+ (car base) (* (fix (* (/ i 25) somenumber)) 100)) (- (cadr base) (* 20 (* i somenumber)))) ) (entmake (list '(0 . "TEXT") (cons 8 currentlayer) (cons 10 base_n) (cons 11 base_n) (cons 40 currenttextsize) (cons 1 tx) (cons 7 currenttextstyle) '(71 . 0) '(72 . 0) '(73 . 2) ) ) (setq i (1+ i)) (setq c (1+ c)) (if (eq c 25) ;simple counter to step over (progn (setq base (polar base (* PI 0.5) (* 500 somenumber))) (setq c 0) ) ) ) (mapcar 'setvar vars vals) ;restore old values (princ) ) (defun AT:NumFix (s n) ;; Fix number string with leading zeros ;; s - Number string to fix ;; n - Number of characters for final string ;; Alan J. Thompson, 10.29.09 (if (< (strlen s) n) (AT:NumFix (strcat "0" s) n) s ) ) 1 Quote Link to comment Share on other sites More sharing options...
mousho Posted June 12, 2022 Author Share Posted June 12, 2022 1 hour ago, exceed said: (defun C:text_table (/ vars vals base i c tx base_n currentlayer currenttextstyle currenttextsize somenumber) (setq vars '(snapmode osmode cmdecho ATTDIA ATTREQ LUPREC) ;list of variables vals (mapcar 'getvar vars) ;store old values ) (mapcar 'setvar vars '(0 0 0 0 1 0)) ;set new values (setq base (getpoint "\nEnter Starting Point :") i 0 c 0 ) (setq currentlayer (getvar 'clayer)) ;edited line (setq currenttextstyle (getvar 'textstyle)) ;edited line (setq currenttextsize (getvar 'textsize)) ;edited line (setq somenumber (/ currenttextsize 8)) (while (< i 1000) (setq tx (strcat (AT:NumFix (itoa i) 4) " = " (chr i)) base_n (polar base (* pi 1.5) (* 20 (* i somenumber))) base_n (list (+ (car base) (* (fix (* (/ i 25) somenumber)) 100)) (- (cadr base) (* 20 (* i somenumber)))) ) (entmake (list '(0 . "TEXT") (cons 8 currentlayer) (cons 10 base_n) (cons 11 base_n) (cons 40 currenttextsize) (cons 1 tx) (cons 7 currenttextstyle) '(71 . 0) '(72 . 0) '(73 . 2) ) ) (setq i (1+ i)) (setq c (1+ c)) (if (eq c 25) ;simple counter to step over (progn (setq base (polar base (* PI 0.5) (* 500 somenumber))) (setq c 0) ) ) ) (mapcar 'setvar vars vals) ;restore old values (princ) ) (defun AT:NumFix (s n) ;; Fix number string with leading zeros ;; s - Number string to fix ;; n - Number of characters for final string ;; Alan J. Thompson, 10.29.09 (if (< (strlen s) n) (AT:NumFix (strcat "0" s) n) s ) ) Perfect 1 Quote Link to comment Share on other sites More sharing options...
