DenDal Posted June 9, 2022 Posted June 9, 2022 Hi I have old drawings that are in 1.25 snap or no snap. I Would like that all my objects ( electrical drawings) would snap to 2.5 setting. How can I snap it to 2.5? Quote
f700es Posted June 9, 2022 Posted June 9, 2022 Shift and Right-Click and select Osnap Settings. This opens up Drafting Settings. Select the 1st tab, Snap and Grid. You should be able to set your snap and grid spacing there. Quote
CyberAngel Posted June 9, 2022 Posted June 9, 2022 You can reach the snap settings from the status bar, if the bar is visible and the snap (not object snap) icon is included. You can type DSETTINGS at the command prompt. It's probably somewhere on the ribbon too. Quote
eldon Posted June 9, 2022 Posted June 9, 2022 You could try the system variable SNAPUNIT, and set it to 2.5,2.5 1 Quote
