I have the attached DWG ,
I need to represents  numbers from 0 to 14 to set speed at a dial cursor , I did it for 0
Up now,  I made it by polar array .
Could it be a lisp or a command  as to make incremental numbers from 0 to 14 clock wise  ?
Thanks in advance
text at dial.dwg
Because you have used array polar
(setq ss (ssget '((0 . "TEXT"))))
; ccw
(setq obj (vlax-ename->vla-object (ssname ss (setq x (- x 1)))))
(vla-put-textstring obj (rtos x 2 0))
;cw
(setq x -1 y (- (sslength ss) 1))
(repeat (sslength ss)
(setq obj (vlax-ename->vla-object (ssname ss (setq x (1+ x)))))
(vla-put-textstring obj (rtos y 2 0))
(setq y (1- Y))
; DIAL - 2022.06.09 exceed
; https://www.cadtutor.net/forum/topic/75376-to-draw-numbers-as-clock-dial/
; Commad : DIAL
; If you specify the center point and start point of the dial, the text is created like the dial with that radius.
; It is judged whether the angle between the center point and the starting point is closer to 0, 90, 180, or 270 degrees,
; and it is taken as the reference line.
; - The starting text is 0.
; - Depending on the number of text input, more numbers can be entered.
; - The size of the text can be adjusted with the TEXTSIZE command.
(vl-load-com)
(defun c:DIAL ( / centerpt startpt textnum startangle dialsize startangle direction exceptangle angle1piece textangle mspace textheight startnum placepoint textobj answer index stringlist objlist )
  (setq centerpt (getpoint "\n pick center point : "))
  (setq startpt (getpoint centerpt "\n pick start point : "))
  (setq textnum (getint "\n input number of texts : "))
  (setq startangle (angle centerpt startpt))
  (setq dialsize (distance centerpt startpt))
  (defun dtr (a) (* pi (/ a 180.0)))
  (defun rtd (a) (/ (* a 180.0) pi))
  (setq startangle (rtd startangle))
  (princ "\n because your start angle is : ")
  (princ startangle)
  (cond
    ((and (>= startangle 0) (< startangle 45))
      (setq direction "CCW")
      (setq exceptangle (* 2 (- startangle 0)))
    ((and (>= startangle 45) (< startangle 90))
      (setq direction "CW")
      (setq exceptangle (* 2 (- 90 startangle)))
    ((and (>= startangle 90) (< startangle 135))
      (setq exceptangle (* 2 (- startangle 90)))
    ((and (>= startangle 135) (< startangle 180))
      (setq exceptangle (* 2 (- 180 startangle)))
    ((and (>= startangle 180) (< startangle 225))
      (setq exceptangle (* 2 (- startangle 180)))
    ((and (>= startangle 225) (< startangle 270))
      (setq exceptangle (* 2 (- 270 startangle)))
    ((and (>= startangle 270) (< startangle 315))
      (setq exceptangle (* 2 (- startangle 270)))
    ((and (>= startangle 315) (< startangle 360))
      (setq exceptangle (* 2 (- 360 startangle)))
  (princ "\n make it : ")
  (princ direction)
  (princ "\n exception angle : ")
  (princ exceptangle)
  (setq angle1piece (/ (- 360 exceptangle) (- textnum 1)))
  (setq textangle startangle)
  (setq mspace (vla-get-modelspace (vla-get-activedocument (vlax-get-acad-object))))
  (setq textheight (getvar 'textsize))
  (setq startnum 0) ; change this if you want to edit the start number
  (setq stringlist '())
  (setq objlist '())
  (repeat textnum
    (setq placepoint (polar centerpt (dtr textangle) dialsize))
    (setq textobj (vla-addtext mspace startnum (vlax-3d-point placepoint) textheight))
    (vlax-put-property textobj 'alignment 10)
    (setq objlist (cons textobj objlist))
    (setq stringlist (cons startnum stringlist))
    (setq startnum (+ startnum 1))
    (cond
      ((= direction "CW")
        (setq textangle (- textangle angle1piece))
      ((= direction "CCW")
        (setq textangle (+ textangle angle1piece))
  );end of repeat
  (setq answer (getstring "\n do you want reverse it? [ SpaceBar - No / Y - Yes ] : \n"))
  (if (= "Y" (strcase answer))
      (setq stringlist (reverse stringlist))
      (setq index 0)
      (repeat textnum
        (vla-put-textstring (nth index objlist) (nth index stringlist))
        (setq index (+ index 1))
    (progn)
);end of defun
It might be a little different from what you're looking for, but for reference.
It only works by specifying two points and entering the number of texts.
The direction of text writing is determined by nearest of 0,90,180,270 degrees, so it can be applied to any angle.
There is no limit to the number, It is also possible to create a 360 degree protractor with 2 orthogonal points and input 361
Edited by exceed
add function - reverse texts Y/N
