samifox Posted June 1, 2022 Posted June 1, 2022 Hi I have authored a dynamic block with” block properties table” controller and dimension and geometric constraint and visibility states, Im looking for a search flexibility where for example I can select all instances in the drawing or a selection set that use visibility A and are 160x80, and other instances that use visibility B and are 110x50,needless to say, they are all instance of the same block. Is there any organic way of doing this? Thanks S Quote
CyberAngel Posted June 1, 2022 Posted June 1, 2022 I've tried to use Select Similar on dynamic blocks, but without much success. Apparently, every instance is considered a different block, or at least every instance that has had some parameter changed from the default. I would guess that it will require some code to find dynamic blocks that share a specific group of settings. Then again I'm a total n00b at dynablocks. Quote
BIGAL Posted June 2, 2022 Posted June 2, 2022 You need to look at Lee-mac dynamic block properties lisp to get properties of a block, as a dynamic block is *U???? by name. You need to use ssget with the *U* blockname, you can then look at the selection set and find the common block which has also a "effective name", then dig deeper getting the properties you want. 1 Quote
samifox Posted June 2, 2022 Author Posted June 2, 2022 1 hour ago, BIGAL said: You need to look at Lee-mac dynamic block properties lisp to get properties of a block, as a dynamic block is *U???? by name. You need to use ssget with the *U* blockname, you can then look at the selection set and find the common block which has also a "effective name", then dig deeper getting the properties you want. yes i relize its possible with coding, i meant to ask if there is builtin way of doing it where LT users can do it as well Quote
SLW210 Posted June 2, 2022 Posted June 2, 2022 Some what of a solution HERE by steven-g Maybe he will chime in here. Quote
SLW210 Posted June 2, 2022 Posted June 2, 2022 I have moved your thread to the AutoCAD LT Forum. Please post in the correct forum. Quote
