Hi every one,
i would be grateful if any one help me to solve my problem,
My active document is Drawing1.dwg and i run my lisp to open Drawing2.dwg and i need to select all item like lines, polylines, texts, ETC. on Drawing2.dwg
i write following code but it is not complete.
(DEFUN C:TEST ()
;open drawing 2
  (SETQ ADOC (VLA-OPEN (VLA-GET-DOCUMENTS (VLA-GET-APPLICATION (VLAX-GET-ACAD-OBJECT))) "D:\\Drawing1.dwg"))
;select items AcadselectionSet
 (SETQ SSETS (VLA-GET-SELECTIONSETS ADOC))
;I need vla-object
;close drawing 2
  (VLA-CLOSE (VLA-ITEM DOC "Drawing1.dwg") :VLAX-FALSE)
Edited by Arash-ET
