Milky Posted May 22, 2022 Posted May 22, 2022 Hi Folks, Drawing below in 3D and i can draw straight line up, along down etc on the 'Front' pane but if i try to draw a rectangle a polyline or anything else ionly draws on the 'top' Not sure what i need to change to sort that. The attached drawing shows what i can do with the Line tool. I'd like to do similar with otheres cheers Quote
Cad64 Posted May 22, 2022 Posted May 22, 2022 Rectangles and Polylines can only be drawn in the XY plane. If you want to create these elements in the Front view you will need to rotate your UCS. Type UCS at the command prompt and hit Enter. Look at the command line to see your options. If you type X and hit Enter, then type 90 and hit Enter, your UCS will rotate 90 degrees around the X axis and you will then be able to draw Polylines and Rectangles in the Front view. Take a look at the link below to learn more about the UCS command. https://knowledge.autodesk.com/support/autocad/learn-explore/caas/CloudHelp/cloudhelp/2016/ENU/AutoCAD-Core/files/GUID-0BE49DA1-B323-4758-B49B-4C497D194C7A-htm.html 2 Quote
BIGAL Posted May 23, 2022 Posted May 23, 2022 Look into Thickness will ad a Z value to lines plines etc. Very simple 3d method. Quote
