supertxull Posted May 19, 2022 Share Posted May 19, 2022 I would like to create a lisp file to add custom properties to my drawings (also Sheet Set properties if it's possible). Where can I find information about it? I would need to create a property name and its value. Thank you in advance for your help. Quote Link to comment Share on other sites More sharing options...
dexus Posted May 19, 2022 Share Posted May 19, 2022 (edited) Below is the code I use to set custom properties: ; Custom dwg properties functions (defun getCustomDwgProp (key / summaryInfo val) (setq summaryInfo (vla-get-summaryInfo (vla-get-activeDocument (vlax-get-acad-object)))) (if (vl-catch-all-error-p (vl-catch-all-apply 'vla-getCustomByKey (list summaryInfo key 'val))) (setq val nil) ) val ) (defun setCustomDwgProp (key value / summaryInfo) (setq summaryInfo (vla-get-summaryInfo (vla-get-activeDocument (vlax-get-acad-object)))) (if (getCustomDwgProp key) (vla-setCustomByKey summaryInfo key value) (vla-addCustomInfo summaryInfo key value) ) ) Edited May 19, 2022 by dexus Quote Link to comment Share on other sites More sharing options...
exceed Posted May 19, 2022 Share Posted May 19, 2022 (edited) (vl-load-com)(vlax-dump-object (vlax-get-property (vla-get-activedocument (vlax-get-acad-object)) 'Summaryinfo) t) Copy this and Paste to the command prompt. you can modify the upper values with get-property/put-property (if that property is not read only) or you can use method in the methods supported list. Edited May 19, 2022 by exceed Quote Link to comment Share on other sites More sharing options...
supertxull Posted May 19, 2022 Author Share Posted May 19, 2022 Thanks! I am going to check it. Quote Link to comment Share on other sites More sharing options...
_Flawgic Posted January 12 Share Posted January 12 is there anyway to add a cumulative GPM count? i do sprinklers and it would help tremendously for zoning. i want to be able to select a group of heads with different gpm values and see their total gallon count similar to cumulative area for hatch Quote Link to comment Share on other sites More sharing options...
BIGAL Posted January 13 Share Posted January 13 What does this have to do with custom properties ? Please Admin move to a new lisp request. For _Flawgic post a sample dwg. Quote Link to comment Share on other sites More sharing options...
hosneyalaa Posted January 13 Share Posted January 13 4 hours ago, BIGAL said: What does this have to do with custom properties ? TEST Command: DWGPROPS Quote Link to comment Share on other sites More sharing options...
BIGAL Posted January 13 Share Posted January 13 (edited) Sorry _Flawgic post, is not relevant to Custom properties question. Admin may fix. Edited January 13 by BIGAL Quote Link to comment Share on other sites More sharing options...
