beyag Posted May 17, 2022 Share Posted May 17, 2022 Hello Everyone, Is there a way to offset a 3D Polyline ? with offset slope (%) and horizontal distance (meter) , as user input. Thanks in advance. Quote Link to comment Share on other sites More sharing options...
Emmanuel Delay Posted May 18, 2022 Share Posted May 18, 2022 Could you upload a drawing that shows the desired outcome? Quote Link to comment Share on other sites More sharing options...
beyag Posted May 18, 2022 Author Share Posted May 18, 2022 3D_Offset.dwg Quote Link to comment Share on other sites More sharing options...
beyag Posted May 19, 2022 Author Share Posted May 19, 2022 There are Autocad add-ons that are able to do this. The problem is that I don't always have access to those add-ons. Quote Link to comment Share on other sites More sharing options...
lrm Posted May 20, 2022 Share Posted May 20, 2022 The following process is tedious but will yield the desired result (I think). Working on a new layer create 4 lines snapping to the vertices of the 3dpoly. Move the 4 lines in Z by - 2.5 ( 50% x 5m offset distance). Select one of the lines and use UCS OB to set a ucs for the line. Use Offset with a distance of 5. Repeat steps 3, 4, and 5 for the other edge lines. This will yield the lines shown in green below. Use chamfer to complete the 3D offset. 2 Quote Link to comment Share on other sites More sharing options...
beyag Posted May 20, 2022 Author Share Posted May 20, 2022 Thanks for the reply, In this example it was a simple shape ( rectangle) But, if it's a more complex shape , with more vertices , it would be impossible to follow the steps you showed. Quote Link to comment Share on other sites More sharing options...
BIGAL Posted May 20, 2022 Share Posted May 20, 2022 For say road kerbs our surveyor would pick up road edge, then add the back of kerb so it is probably easier to off set correct distance then move vertically a % or ht. Quote Link to comment Share on other sites More sharing options...
beyag Posted May 20, 2022 Author Share Posted May 20, 2022 offset.mp4 This video shows how I usually get it done. Quote Link to comment Share on other sites More sharing options...
