Kowal Posted May 15, 2022 Share Posted May 15, 2022 (defun c:runm (/ abks aexc asht find x xbks xlpath xshts) (if (not (findfile (setq xlpath (strcat (getvar "dwgprefix") "4" ".xlsm"))));<-- full path of your Excel file, change to suit (progn (alert "File does not exist") (exit) (princ) );progn );if (alert "Close Excel File Save Changes") (setq aexc (vlax-get-or-create-object "Excel.Application")) (setq xbks (vlax-get-property aexc "Workbooks")) (if (not (vl-file-systime xlpath)) (progn (setq find nil) (setq abks (vlax-invoke-method xbks "Add")) );progn (progn (setq find T) (setq abks (vlax-invoke-method xbks "Open" xlpath)) );progn );if (setq xshts (vlax-get-property abks "Sheets")) (setq asht (vlax-get-property xshts "Item" 1)) ;<-- sheet number - optional not used in this program (vla-put-visible aexc :vlax-true) (vlax-put-property aexc "ScreenUpdating" :vlax-true) ; to see changes (vlax-put-property aexc "DisplayAlerts" :vlax-true) ; to initialize user interaction (vlax-invoke-method asht "Activate") ;optional not used in this program (vlax-invoke-method aexc "Run" "Print_all") ;<-- macro name in the Excel file (vlax-invoke xbks "Close") (vlax-invoke aexc "Quit") (princ) ) Hi, I would like to do this scenario: open the .xlsm file, run the macro in the .xlsm file, save the changes, close the file. The only thing I miss is saving the changes before closing. If I remove the code responsible for running macros, the files are closed. (vlax-invoke-method aexc "Run" "Print_all") Please help me save the changes after running the macro and closing the file. If someone has a similar working lisp please share it. Quote Link to comment Share on other sites More sharing options...
BIGAL Posted May 15, 2022 Share Posted May 15, 2022 I have no idea what is in your macro but have you thought about putting that code into Autocad so it does the same thing as the macro ? The other way is have your excel macro talk to Autocad its the same method open a Application. Attached is an example macro of Excel making objects in Autocad. (defun closeexcel ( / ) (if (= ah:ex "T") (vlax-invoke-method (vlax-get-property myxl "ActiveWorkbook") 'Close :vlax-False) (vlax-invoke-method (vlax-get-property myxl "ActiveWorkbook") "SaveAs" filename -4143 "" "" :vlax-false :vlax-false nil ) ) excel vba draw acad.txt 1 Quote Link to comment Share on other sites More sharing options...
