(defun c:runm (/ abks aexc asht find x xbks xlpath xshts)
  (if (not (findfile
	     (setq xlpath (strcat (getvar "dwgprefix") "4" ".xlsm"))));<-- full path of your Excel file, change to suit
      (alert "File does not exist")
      (exit)
      );progn
    );if
  (alert "Close Excel File Save Changes")
  (setq aexc (vlax-get-or-create-object "Excel.Application"))
  (setq xbks (vlax-get-property aexc "Workbooks"))
  (if (not (vl-file-systime xlpath))
      (setq find nil)
      (setq abks (vlax-invoke-method xbks "Add"))
      );progn
      (setq find T)
      (setq abks (vlax-invoke-method xbks "Open" xlpath))
      );progn
    );if
  (setq xshts (vlax-get-property abks "Sheets"))
  (setq asht (vlax-get-property xshts "Item" 1)) ;<-- sheet number - optional not used in this program
  (vla-put-visible aexc :vlax-true)
  (vlax-put-property aexc "ScreenUpdating" :vlax-true) ; to see changes
  (vlax-put-property aexc "DisplayAlerts" :vlax-true) ; to initialize user interaction
  (vlax-invoke-method asht "Activate") ;optional not used in this program
  (vlax-invoke-method aexc "Run" "Print_all") ;<-- macro name in the Excel file
  (vlax-invoke xbks "Close")
(vlax-invoke aexc "Quit")
Hi,
I would like to do this scenario: open the .xlsm file, run the macro in the .xlsm file, save the changes, close the file.
The only thing I miss is saving the changes before closing.
If I remove the code responsible for running macros, the files are closed.
Please help me save the changes after running the macro and closing the file.
If someone has a similar working lisp please share it.
I have no idea what is in your macro but have you thought about putting that code into Autocad so it does the same thing as the macro ?
The other way is have your excel macro talk to Autocad its the same method open a Application.
Attached is an example macro of Excel making objects in Autocad.
(defun closeexcel ( / )
(if (= ah:ex "T")
(vlax-invoke-method (vlax-get-property myxl "ActiveWorkbook") 'Close :vlax-False)
(vlax-invoke-method (vlax-get-property myxl "ActiveWorkbook")  "SaveAs" filename -4143 "" "" :vlax-false :vlax-false nil )
excel vba draw acad.txt
