aridzv Posted May 14, 2022 Posted May 14, 2022 (edited) Hi. I have found this lisp INTLINES that draw a point in every intersection of a selected objects. lets say I have 3 layers - L1,L2,L3. I'm looking for help to add to this lisp the possibilty to choose to draw the points only in intersection between objects that belong to layers L1 and L3 (see attached screenshot that illustrate the problem and a sample drawing). thanks, Ari. new block.dwg cdnc5-02.lsp Edited May 14, 2022 by aridzv Quote
lido Posted May 15, 2022 Posted May 15, 2022 ;; (setq SS1 (ssget);(ssget "_X");(get_all_lines_as_SS) (setq SS1 (ssget '((-4 . "<OR") (8 . "L1") (8 . "L2")(-4 . "OR>"))) PTS (get_all_inters_in_ss SS1) ) On line 118 of the program, with the function "ssget", use the logical operator "OR" to restrict the selection to layers "L1" or "L2". 1 Quote
Tharwat Posted May 15, 2022 Posted May 15, 2022 @lido FYI in this case you can just concatenate the layer names with comma, like: (8 . "L1,L2") without the use of 'OR" logic operator. 1 1 Quote
lido Posted May 15, 2022 Posted May 15, 2022 11 minutes ago, Tharwat said: @lido FYI in this case you can just concatenate the layer names with comma, like: (8 . "L1,L2") without the use of 'OR" logic operator. @Tharwat Of course, your solution is simpler and more direct. 1 Quote
aridzv Posted May 20, 2022 Author Posted May 20, 2022 (edited) Hi. here is the final updated lisp. There are 2 changes from the original lisp: 1. the 2 layers are not hard-codded in the lisp,but the lisp prompt the user to select them. 2. the points are drawn on the second layer (submain layer) regardles of the drawing current layer. thanks again for all the help, Ari. INTLINES_UPDATE.lsp Edited May 21, 2022 by aridzv Quote
