sinanp Posted February 15, 2009 Posted February 15, 2009 Hi Relatively new to Rhino and a couple of questions, I have a model that is pretty complicated, in retrospect too complicated but I haven't got time to redo it and struggling to get some 2d drawings out of the model using the make2d command, I set up the internal view I need and start the make 2d command, still by the following morning it hasn't finished! Is there a quicker/ better way to extract info? Also strangely on a file I am working the accuracy in positioning has gone a bit bonkers compared to previous rhino files I worked on. For example with the snaps on, say end snap I position the polyline over the end of another polyline, but it snaps mysteriously off to one site, shifting around as I move the mouse but never on the end point as it used to, when I click to complete it kind of ends up starting the new polyline from the end of the existing polyline but not always, sometimes off to one side. I had a look at the options compared to earlier files that were fine but can't see any changes. Any ideas? thanks Quote
TedKyte Posted February 16, 2009 Posted February 16, 2009 sinanp said: Hi Relatively new to Rhino and a couple of questions, I have a model that is pretty complicated, in retrospect too complicated but I haven't got time to redo it and struggling to get some 2d drawings out of the model using the make2d command, I set up the internal view I need and start the make 2d command, still by the following morning it hasn't finished! Is there a quicker/ better way to extract info? thanks Try setting your view and then zooming way out before you start the make2D command. That should speed it up considerably. Quote
andrej Posted February 18, 2009 Posted February 18, 2009 make2d takes ages and comes out illegible if you're making2d objects that extend outside of the viewport (especially interior views). to get around this you need to crop the objects to the viewport frame. not sure if this is affecting what you're attempting.. hope it helps anyhow. Quote
sinanp Posted February 18, 2009 Author Posted February 18, 2009 Ah, I thought that might be an issue, how do you crop based on a view in Rhino? Quote
andrej Posted February 19, 2009 Posted February 19, 2009 whilst in the viewport you want to make2d type: camera show then in another viewport draw points connecting the points that define the view. draw surfaces connecting the points. scale the surfaces up. use the surfaces to split the objects that extend through them. Quote
