Benjamin Posted May 13, 2022 Posted May 13, 2022 Hi! My question is the following: Can C3d be forced to place a ditch on the side slope of an embankment? I need to give continuity to a ditch that comes from a cut condition until reach the discharging point. I tried using the BasicSideSlopeCutDitch command to do it, but i can't. Do you have any advice? Thank you, for your help! Benjamin Quote
CyberAngel Posted June 20, 2022 Posted June 20, 2022 Have you tried the DaylightBasin subassembly? You can pretend your ditch is a basin and interrupt the slope, then continue the slope to the existing grade. You can define the slope or the width of either side of the ditch. 1 Quote
