Civil 3d, Ditch subassembly in fill condition
Hi!
My question is the following: Can C3d be forced to place a ditch on the side slope of an embankment?  I need to give continuity to a ditch that comes from a cut condition until reach the discharging point.  I tried using the BasicSideSlopeCutDitch command to do it, but i can't.  Do you have any advice?
Thank you, for your help!
Benjamin
  • 1 month later...
Have you tried the DaylightBasin subassembly? You can pretend your ditch is a basin and interrupt the slope, then continue the slope to the existing grade. You can define the slope or the width of either side of the ditch.
