RLispLearner Posted May 13, 2022 Posted May 13, 2022 Hi all, I am getting a DXF code error (on group code 10 I believe) when I try to create a center point for my circle based on math. Perhaps I have the wrong syntax . Does someone see the issue by chance? FYI: When the routine works, there should be a rectangle with a midpoint line on the longest side and a 24 diameter circle at each end of the midpoint line. Thanks in advance everyone! Code: ;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;; ;;; Create a rectangle. Draw a midpoint line on the longest side of a rectangle ;;;; ;;; Put a 24 diameter circle at each end of the midpoint line drawn ;;;; ;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;; ;;; (defun c:midlinecircles (/ mylength mywidth mylengthmid1 mylengthmid2 mywidthmid1 mywidthmid2 pt1 pt2 pt3 pt4 pt5 pt6 pt7 pt8 ) (VL-LOAD-COM) (command-s "_.rectang"); [draw area for rectangle] (setq pt1 (vlax-curve-getPointAtParam (entlast) 0) pt2 (vlax-curve-getPointAtParam (entlast) 1) pt3 (vlax-curve-getPointAtParam (entlast) 2) pt4 (vlax-curve-getPointAtParam (entlast) 3) ); ;Get length and width of rectangle (setq mylength (distance pt1 pt2)); length (setq mywidth (distance pt1 pt4)); width ;Find the mid point of each side of the rectangle ; (setq mylengthmid1 (/ (distance pt1 pt2) 2)) ; mid point of length on one side of rectangle (setq mylengthmid2 (/ (distance pt3 pt4) 2)); mid point of length on the opposite side of rectangle ; (setq mywidthmid1 (/ (distance pt2 pt3) 2)) ;mid point of width on one side of rectangle (setq mywidthmid2 (/ (distance pt1 pt4) 2)) ;mid point of width on the opposite side of rectangle ; ; ; ; ;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;; ;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;; ; ; ; ;Find out which is the shorter side of the rectangle and then draw a line between the midpoints ; (if (> mywidth mylength); if mywidth is more than my length * 2 ( if true then...) ;; (Progn (setq pt5 (/ (distance pt2 pt3) 2)) (setq pt6 (/ (distance pt1 pt4) 2)) (entmake (list '(0 . "LINE") (cons 10 (polar pt2 (angle pt2 pt3) (/ (distance pt2 pt3) 2))) (cons 11 (polar pt1 (angle pt1 pt4) (/ (distance pt1 pt4) 2))) ;; put the line on a layer '(8 . "MIDPOINTLINE") ;;color white '(62 . 7) ) ;Draw a circle at the end of the midpoints with diameter of 24 (entmake (list '(0 . "CIRCLE") (cons 10 (/ (distance pt2 pt3) 2)) (cons 40 48); size 24 diameter ) ) (entmake (list '(0 . "CIRCLE") (cons 10 (/ (distance pt1 pt4) 2)) (cons 40 48); size 24 diameter ) ) ;Draw a circle at the end of the midpoints ;(command "_circle" pt5 "D" 24); Doesnt work ;(command "_circle" pt6 "D" 24); Doesnt work );End Progn );End IF ; If its not true then... ; (Progn (setq pt7 (/ (distance pt1 pt2) 2)) (setq pt8 (/ (distance pt3 pt4) 2)) (entmake (list '(0 . "LINE") (cons 10 (polar pt1 (angle pt1 pt2) (/ (distance pt1 pt2) 2))) (cons 11 (polar pt3 (angle pt3 pt4) (/ (distance pt3 pt4) 2))) ;; put the line on a layer '(8 . "MIDPOINTLINE") ;;line to color white '(62 . 7) ) ;Draw a circle at the end of the midpoints with diameter of 24 (entmake (list '(0 . "CIRCLE") (cons 10 (/ (distance pt1 pt2) 2)) (cons 40 48); size 24 diameter ) ) (entmake (list '(0 . "CIRCLE") (cons 10 (/ (distance pt3 pt4) 2)) (cons 40 48); size 24 diameter ) ) ;Draw a circle at the end of the midpoints ;(command "_circle" pt7 "D" 24); Doesnt work ;(command "_circle" pt8 "D" 24); Doesnt work ); End Draw a line from mid points mylengthmid1 to mylengthmid2 );End Progn ) ;_ if ); End Program Quote
Isaac26a Posted May 13, 2022 Posted May 13, 2022 I think this will work better ;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;; ;;; Create a rectangle. Draw a midpoint line on the longest side of a rectangle ;;;; ;;; Put a 24 diameter circle at each end of the midpoint line drawn ;;;; ;;; Mods by Isaac A. ;;;; ;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;; (defun c:midlinecircles (/ mylength mywidth oldecho pt1 pt2 pt3 pt4 pt5 pt6) (vl-load-com) (setq oldecho (getvar 'cmdecho)) (setvar 'cmdecho 0) (setq pt1 (getpoint "\nPick the first point") pt3 (getcorner "\Pick the next corner" pt1) ) (vl-cmdf "_.rectang" pt1 pt3) (setq pt2 (vlax-curve-getPointAtParam (entlast) 1) pt4 (vlax-curve-getPointAtParam (entlast) 3) ) ;Get length and width of rectangle (setq mylength (distance pt1 pt2)); length (setq mywidth (distance pt1 pt4)) ; width ;Find out which is the shorter side of the rectangle and then draw a line between the midpoints (if (> mywidth mylength); if mywidth is greather than mylength ( if true then...) (progn (setq pt5 (list (/ (+ (car pt1) (car pt4)) 2) (/ (+ (cadr pt1) (cadr pt4)) 2))) (setq pt6 (list (/ (+ (car pt2) (car pt3)) 2) (/ (+ (cadr pt2) (cadr pt3)) 2))) (entmake (list '(0 . "LINE") (cons 10 pt5) (cons 11 pt6) ;; put the line on a layer '(8 . "MIDPOINTLINE") ;;color white '(62 . 7) ) ) ;Draw a circle at the end of the midpoints with diameter of 24 (entmake (list '(0 . "CIRCLE") (cons 10 pt5) (cons 40 12); size 24 diameter ) ) (entmake (list '(0 . "CIRCLE") (cons 10 pt6) (cons 40 12); size 24 diameter ) ) );End Progn ; If its not true then... (progn (setq pt5 (list (/ (+ (car pt1) (car pt2)) 2) (/ (+ (cadr pt1) (cadr pt2)) 2))) (setq pt6 (list (/ (+ (car pt3) (car pt4)) 2) (/ (+ (cadr pt3) (cadr pt4)) 2))) (entmake (list '(0 . "LINE") (cons 10 pt5) (cons 11 pt6) ;; put the line on a layer '(8 . "MIDPOINTLINE") ;;color white '(62 . 7) ) ) ;Draw a circle at the end of the midpoints with diameter of 24 (entmake (list '(0 . "CIRCLE") (cons 10 pt5) (cons 40 12); size 24 diameter ) ) (entmake (list '(0 . "CIRCLE") (cons 10 pt6) (cons 40 12); size 24 diameter ) ) ) ;End Progn ) ;_ if (setvar 'cmdecho oldecho) ); End Program Quote
Isaac26a Posted May 14, 2022 Posted May 14, 2022 9 hours ago, RLispLearner said: Thanks Isaac. This is a big help! You're welcome Quote
BIGAL Posted May 15, 2022 Posted May 15, 2022 Another hint mid pt of 2 pts (setq mp (mapcar '* (mapcar '+ pt1 pt2) '(0.5 0.5))) 1 Quote
Isaac26a Posted May 15, 2022 Posted May 15, 2022 15 hours ago, BIGAL said: Another hint mid pt of 2 pts (setq mp (mapcar '* (mapcar '+ pt1 pt2) '(0.5 0.5))) Thank you BigAl it never crossed my mind, it's much less code Quote
