MJLM Posted May 11, 2022 Posted May 11, 2022 Hi, I have made my fast selection routine that collects members of a network as a chain and returning as a selection set . I would like to get the returning ss running it as transparent, that is while already being inside an other routine on an active ssget prompt, type 'my_fast_selection_commad and get the ss coming from the transparent command. From what I have tried, it seems it is not possible? Can a transparent command return anything apart from nil? Quote
Steven P Posted May 11, 2022 Posted May 11, 2022 So if I am reading this correctly you ant something like: (not in code tags since this isn't really code, just the idea) (defun c:testlisp ( / ) [Do some setp stuff] (setq MySS (ssget... get selection se) [But can type in (my_fast_selection_command) in setq MySS (my_fast_selection_command)] [do more stuff] ) I have something that will do this with an entsel, rather than a selection set I think - it might be able to be modified using SS I think using a while loop and an initget night be working something like (setq endloop "No") (initget my_fast_selection_command) (whle (= "No" endloop) (if getsting "my_fast_selection_command (progn (setq MySS (my_fast_selection_command))(setq endloop "Yes"))) (setq MySS (ssget...)) );end while Somthing like that if I remember what I did correctly - gives you smething to thinkaboutfor now anyway. Quote
BIGAL Posted May 11, 2022 Posted May 11, 2022 Maybe this example of a erase shortcut note the transparent 'ZZZ must use single quote for transparent. (defun c:zzz () (ssget "X" '((0 . "LINE")))) Erase 'zzz Enter 1 Quote
Steven P Posted May 12, 2022 Posted May 12, 2022 8 hours ago, BIGAL said: Maybe this example of a erase shortcut note the transparent 'ZZZ must use single quote for transparent. (defun c:zzz () (ssget "X" '((0 . "LINE")))) Erase 'zzz Enter That's new to me! Thanks Quote
