pmadhwal7 Posted May 6, 2022 Posted May 6, 2022 Hi supposed my dwg has 100 layout sheets and I want to put the layout number in each layout how it was possible in an automatic way, sample attached Layout.dwg Quote
ronjonp Posted May 6, 2022 Posted May 6, 2022 (edited) Use a FIELD: %<\AcVar ctab>% Layout.dwg Edited May 6, 2022 by ronjonp 1 Quote
pmadhwal7 Posted May 7, 2022 Author Posted May 7, 2022 9 hours ago, ronjonp said: Use a FIELD: %<\AcVar ctab>% Layout.dwg 97.6 kB · 0 downloads actually, i want those text inside the layout sheet 1 Quote
mhupp Posted May 7, 2022 Posted May 7, 2022 12 minutes ago, pmadhwal7 said: actually, i want those text inside the layout sheet So create a text with that field inside the layout sheet. if its not a block you can use this to copy to the rest of the tabs https://cadtips.cadalyst.com/2d-operations/copy-all-layouts 1 Quote
Steven P Posted May 7, 2022 Posted May 7, 2022 (edited) By LISP: (layoutlist) will give you a list of layout names (command "layout" "r" (nth x (layoutlist)) "-NEWNAME-") will rename layouts, here layout number x Make a loop the length of your layout list, and rename accordingly. If you need to grab the layout name from say, a block in each layout, this will take you to layout 'x' (setvar "ctab" (nth x (layoutlist))) wuill take you to the nth layout in your drawing Just need to put is all together, ask if you get stuck but that is the basics Or go here: https://forums.autodesk.com/t5/autocad-forum/lisp-routine-to-rename-all-the-layouts/td-p/3511636 EDIT Whoops got this the wrong way round, that was renaming sheets not a adding the sheet name into the drawing Use the (setvar... part to loop through the sheets, use (nth x (layoutlist)) to get the layout name and then edit the text as you want in the sheet from there, noticing that your sheet name isn't a field but is text? Edited May 7, 2022 by Steven P 1 Quote
tombu Posted May 7, 2022 Posted May 7, 2022 Check out Lee Mac's lisp Layout Field http://lee-mac.com/layoutfield.html 1 Quote
pmadhwal7 Posted May 8, 2022 Author Posted May 8, 2022 Hi all, please check what i need, select all layouts and mark numbers, like i did through this lisp Quote
BIGAL Posted May 9, 2022 Posted May 9, 2022 (edited) This is my attempt, choose title block, choose scale, it then generates rectangs, then next step make layouts that match. Next step is do say "1 of 8" in title block. So need a title block, there is more functions, copy attributes from 1 layout to all layouts, rotate North point to match viewport, add grid in papersapce, to mention a few. I am happy to discuss these options but they do have a small fee as they were developed as a commercial answer. Send a PM to me with your email and we can discuss. Thinking again even more INDEX.lsp, plus all the plot routines. Edited May 9, 2022 by BIGAL Quote
pmadhwal7 Posted May 9, 2022 Author Posted May 9, 2022 6 hours ago, BIGAL said: This is my attempt, choose title block, choose scale, it then generates rectangs, then next step make layouts that match. Next step is do say "1 of 8" in title block. So need a title block, there is more functions, copy attributes from 1 layout to all layouts, rotate North point to match viewport, add grid in papersapce, to mention a few. I am happy to discuss these options but they do have a small fee as they were developed as a commercial answer. Send a PM to me with your email and we can discuss. Thinking again even more INDEX.lsp, plus all the plot routines. Hi actually, this is a very small activity, but we have many types of activity which is required to devolve tool if you can do this for us we can discuss Quote
ronjonp Posted May 9, 2022 Posted May 9, 2022 On 5/6/2022 at 9:58 PM, pmadhwal7 said: actually, i want those text inside the layout sheet You should learn how to use blocks with attributes for your titleblocks. Then put that field in one attribute ( or make it the default value ) and all your sheets will automagically number themselves. Code is not needed for this simple task. 1 Quote
