Using external function within a routine
I'm trying to use the Express Tools' Tcircle command within an app I'm trying to write. What I want to do is put a rectangle around the last entity created (text). But it hangs at "Select TEXT, MTEXT or ATTDEF objects..." and I can't seem to pass the required info programmatically. Anyone know how? This is what I've tried
(command (c:tcircle) "l" "" "0.3" "r" "")
Thanks- Larry
  • Replies 33
  • lpseifert
    10
  • Lee Mac
    7
  • jammie
    4
  • alanjt
    4
i dont have have autocad @ home so i carnt test and see wat the command requires but
You were almost correct.
when you want a command to run, place the name in "" and the rest should follow :P
also not sure if you aware of 'entlast' aka "L" just fyi
(command [color=Red]"tcircle"[/color] "l" "" "0.3" "r" "")
flower
I must admit, I have always had trouble with using the Express tools within other LISPs, as they seem to take control and mess up my LISP after completion, so I'd be interested if Flower's solution works.
Do you know where the express tools lsp are located and are they incripted.
since i some how broke one of them, and that way you can borrow their code and place in in yours
Thanks, I tried that but it gives me the error 'unknown command "tcircle"'
Yes, I'm aware of entlast, but I can't get passed "Select TEXT...
The Tcircle command works fine by itself, and it works inside the app I'm writing if I supply the necessary options, I was hoping to pass them programmatically without the need to enter them manually.
As Flower says, - the reckon the best thing to do is hack into the express tool LISPs :P
***cough****location??*****cough***
I can't seem to find tcircle.lsp or a .lsp that has tcircle. It must be a .fas file.
You cant call external functions like tcircle and pass them values unless they have been set up to accept values. The tcircle file is located at “c:/program files\\express” the file name is acettxt.lsp
OK Thanks. I took a look and the code is beyond me. I guess I'll go to Plan B.
Here a little help for your plan B:
In your program make a call to this code and pass it 2 variables the first must be the entity name of the text the second is an offset distance of the rectangle from the text.
In your code after you have it makes the text write (setq txent (entlast)) this will get the entity name of the last thing made in the drawing, which should be the text.
Now make the call to the code I supplied:(mk_rect txent 0.0313) this calls the mk_rect routine and passes the 2 variables: txext which is the entity name and a real number that can be anything for the offset.
[font=Times New Roman][font=Times New Roman](vl-load-com);_make sure vl commands are loded[/font]
[font=Times New Roman];;;pass 2 variables to the mk_rect function aug1 = entity aug2 = offset distance[/font]
[font=Times New Roman](defun mk_rect (aug1 aug2 / rect llc urc ang1 dist lent)[/font]
[font=Times New Roman](vla-GetBoundingBox (vlax-ename->vla-object aug1) 'minpt 'maxpt);_check for heigth /width[/font]
[font=Times New Roman](setq[/font]
[font=Times New Roman]llc (vlax-safearray->list minpt)[/font]
[font=Times New Roman]urc (vlax-safearray->list maxpt)[/font]
[font=Times New Roman]);_setq[/font]
[font=Times New Roman](setq rtlst(textbox (list(assoc 1 (entget aug1)))));_get true outline on text returns a lower left and upper right[/font]
[font=Times New Roman](setq ang1 (angle (nth 0 rtlst) (nth 1 rtlst)));_ angle from lower left ro upper right[/font]
[font=Times New Roman](setq dst  (distance (nth 0 rtlst) (nth 1 rtlst)));_ distance from lower left ro upper right[/font]
[font=Times New Roman]       (command "rectangle" llc (polar llc ang1 dst));_make rectangle to exact sixe[/font]
[font=Times New Roman](setq lent (entlast));_get rectanglwe entity name for deletion[/font]
[font=Times New Roman](vla-offset (vlax-ename->vla-object (entlast)) aug2);_offset rectangle [/font]
[font=Times New Roman](entdel lent);_delete first rectangle[/font]
[font=Times New Roman](princ)  [/font]
[font=Times New Roman]  );_defun [/font]
[/font]
Once you have turned control over to an external program, you cannot interface with it via an Autolisp app. The external app must either complete it's task or terminate via a cancel.
Unless it has changed over the years, (command (c:myfoo) ... should not work
As to whether you have to use (c:myfoo) or (myfoo), it would either very difficult or impossible to test for, just trial and error.
Command: (type acad_strlsort)
EXRXSUBR
Command: (type c:wipeout)
SUBR
Command: (type c:a2)
SUBR
-David
A slight work about could be to create a temporary script file that you can call and run during your own routine. The script can be evaluated but allows your routine to still run when your script is finished
(setq fname (vl-filename-mktemp "test.scr")
     file  (open fname "w"))
(foreach n (list "tcircle" "l" "" "0.3" "r" "")
 (write-line n file)
(close file)
(command "script" fname)
(vl-file-delete fname)
Hmmm, never though about using a script within an AutoLISP routine - would this be feasible?
For less complex functions I believe it is feasible.
The following example prompts the user to create a text string an calls on the tcircle command to enclose it
(defun c:revtxt	()
 (vl-load-com)
 (setq os (getvar "osmode"))
 (setq	pt  (getpoint "\nSpecify start point of text :")
str (getstring t "\nType text :")
 (vl-cmdf "text" pt 1 "" str)
 (setvar "osmode" 0)
	   "l"
	   (rtos (getreal "\nOffset factor : ") 2 13)
	   "r"
   (write-line n file)
 (close file)
 (vl-cmdf "script" fname)
 (setvar "osmode" os)
everything is cool but the line:
it should be:
(vl-cmdf "text" pt "" str)
and then it works
[/font]
Thanks John, your code works great. Unfortunately the code I'm writing is for labeling storm sewer pipes, and they are rarely horizontal. Our standard is to align the text with the pipe and enclose it with a rectangle. The code you graciously provided creates a rectangle that is horizontal. I've tried mucking around using polar and setting the 4 corners, etc. but it doesn't want to cooperate.
 (write-line n file)
(close file)
jammie, that's pretty clever how you made a script file on the fly, I would have never thought of that. Works well but I notice it seems to run the script at the end of the function. I saved the current layer so it could be restored, changed the clayer to what I want the text and rectangle to be on, but when I run the code the rectangle always ends on the original layer. I tried chprop > entlast... and reordering the lines of code but neither seems to help. Probably along the same lines, after completing the c: function and you hit enter to repeat the function, you get the the prompts for the Tcircle command. Little things I can live with...
Thanks for your help
Glad to be of help.
I encountered a similar stumbling block myslef where I wanted to manipulate an external routine without rewriting the code. I wrote a routine that effectively mimiced all the inputs, skipping the ones that I did not require and wrote the sequence to a script file. I then simply ran the script file
That is a good observation, I hadn't noticed that myself. I not sure exactly why AutoCAD does it...
Maybe this could work instead
(foreach n (list "tcircle" "l" "" "0.3" "r" "" "chprop" "l" "" "la" "<layname>" "")
 (write-line n file)
(close file)
Regards,
Jammie
That works great... more than one way to skin a cat
Thanks Jammie
