I have been using this alot lately. Great routine. I was wondering how I could swap the reference from being parallel to being 90 degrees of the selected line object.
(defun c:foo (/ _foo e i s)
  (defun _foo (e) (abs (angle (vlax-curve-getstartpoint e) (vlax-curve-getendpoint e))))
  (if (and (setq e (car (entsel "\nSelect Line to for Parallel Reference: ")))
	   (setq i (_foo e))
	   (setq s (ssget "_X"
			  '((-4 . "<OR")
			    (0 . "line")
			    (-4 . "<AND")
			    (0 . "*polyline")
			    (90 . 2)
			    (-4 . "AND>")
			    (-4 . "OR>")
    (progn (foreach pl (mapcar 'cadr (ssnamex s))
	     (if (not (or (equal (setq a (_foo pl)) i 1e-3) (equal (/ pi 2 a) i 1e-3))) ;;<<--- (/ pi 2 a) from (+ pi a)
	       (ssdel pl s)
	   (sssetfirst nil s)
Thanks for the help.
Add 90° aka π/2 when calculating i in the 4th line.
-Edit-
had to keep the angle  within 360 so it checks if the (_foo e) angle is less then 270 to add 90 or it will subtract 90.
Horizontal lines would make a = 0 and would error with when dividing by 0 or does in Bricscad. added back in (+ pi a) and (- pi a)
very neat code. going to have to remember the _foo mini function for the future.
  (if (and (setq e (car (entsel "\nSelect Line to for Perpendicular Reference: ")))
        (if (< (setq i (_foo e)) (/ (* 3 pi) 2))
          (setq i (+ i (/ pi 2)))
          (setq i (- i (/ pi 2)))
        (setq s (ssget "_X"
                       '((-4 . "<OR")
                             (0 . "line")
                             (-4 . "<AND")
                             (0 . "*polyline")
                             (90 . 2)
                             (-4 . "AND>")
                             (-4 . "OR>")
        (if (or (equal (setq a (_foo pl)) i 1e-3) (equal (abs (- pi a)) i 1e-3) (equal (abs (+ pi a)) i 1e-3))
          (progn)
          (ssdel pl s)
      (sssetfirst nil s)
  (prompt (strcat "\n" (rtos (sslength s) 2 0) " Lines found"))
Edited by mhupp
Well, I think Mr Ron did this code originally. So he is the one master mind on this.
Thank you for clarifying how to get this to work. Appreciate it alot.
