Ellis Posted May 2, 2022 Share Posted May 2, 2022 I have not had this problem before but i have been getting drawings from my boss. He sent me a drawing last week and i couldn't do it because my mouse was so laggy. He sent me other drawings after and they are fine. Then today i have the same problem with this drawing too. These drawings are not big, i open a bigger drawing while this is open and it works fine. So i don't think it's a hardware problem. I have tried to add it into other drawings incase the file was currupt, it just makes that one lag too. ive tried all the things online to sort out lag but none of it worked. audit, purge, hardware acceleration, updated drivers. He can use the file fine on his computer and another one in the office can use it normal too, only my laptop has the problem. (my laptop is better than the computers in the office) i'm using autocad 2018. If anyone has a solution i'd greatly appreciate it. Quote Link to comment Share on other sites More sharing options...
BIGAL Posted May 2, 2022 Share Posted May 2, 2022 Check GRID & SNAP turn off. 1 Quote Link to comment Share on other sites More sharing options...
Ellis Posted May 3, 2022 Author Share Posted May 3, 2022 6 hours ago, BIGAL said: Check GRID & SNAP turn off. Yeah, ive tried that. Sadly it doesnt help. Quote Link to comment Share on other sites More sharing options...
Cad64 Posted May 3, 2022 Share Posted May 3, 2022 Does the drawing contain a lot of image attachments or hatching? Quote Link to comment Share on other sites More sharing options...
tombu Posted May 3, 2022 Share Posted May 3, 2022 Does the cursor appear to stick to objects? Try setting the ROLLOVERTIPS (System Variable) to 0 to shut them off. I added a macro to toggle them Off/On: Command Name Rollover Tooltips Description Rollover Tooltips toggle Macro ^P(ai_onoff "rollovertips") ^P After adding it to the ribbon add the display name: $(if,$(getvar,rollovertips),!.)Rollover Tooltips Then it will display highlighted when toggled on. 1 Quote Link to comment Share on other sites More sharing options...
Ellis Posted May 5, 2022 Author Share Posted May 5, 2022 On 5/4/2022 at 1:59 AM, Cad64 said: Does the drawing contain a lot of image attachments or hatching? No, its only a .3mb drawing. Pretty simple topographical survey. Quote Link to comment Share on other sites More sharing options...
Ellis Posted May 5, 2022 Author Share Posted May 5, 2022 On 5/4/2022 at 2:23 AM, tombu said: Does the cursor appear to stick to objects? Try setting the ROLLOVERTIPS (System Variable) to 0 to shut them off. I added a macro to toggle them Off/On: Command Name Rollover Tooltips Description Rollover Tooltips toggle Macro ^P(ai_onoff "rollovertips") ^P After adding it to the ribbon add the display name: $(if,$(getvar,rollovertips),!.)Rollover Tooltips Then it will display highlighted when toggled on. I think this might have fixed the issue, thankyou 1 Quote Link to comment Share on other sites More sharing options...
