I've tried this as a select previous but it doesn't seem to work. (One space after _P)
$M=$(if,$(getvar,cmdactive),,_select;)_p
And also (Two spaces after _P)
^C^C_select _P
What I want is for it to behave like it does with the SELECT command and two enters to select them.
With
(defun c:prev (/)(sssetfirst nil (ssget "P"))(princ))
in my acaddoc.lsp this macro works for me
$M=$(if,$(getvar,cmdactive),_previous,prev)
with RCDATA_16_SELPRE as the image.
For Select All
$M=$(if,$(getvar,cmdactive),_all,^P_ai_selall ^P)
with RCDATA_16_SELALL as the image.
for Last
(defun c:lastob (/)(sssetfirst nil (ssget "L"))(princ))
^P$M=$(if,$(getvar,cmdactive),_last,LastOb)
with RCDATA_16_SELLAS as the image.
Thanks tombu. I'll implement that.
It's strange this cannot be assigned directly.
Here's a thread about the same thing. https://forums.autodesk.com/t5/autocad-lt-forum/trying-to-make-the-quot-select-previous-quot-shortcut-key-work/td-p/5373373
Closest to working is (but this requires the enter key to be pressed)
^C^CSelect\p;;
I've ended up going with this:
$M=$(if,$(getvar,cmdactive),,QSPREVIOUS)
And:
(defun c:QSPREVIOUS ( / ss1 )
  (if (setq ss1 (ssget "P"))
    (progn (princ (strcat "\n: ------------------------------\n\t\t<<< "(itoa (sslength ss1)) (if (> (sslength ss1) 1) " <<< OBJECTS" " <<< OBJECT") " selected\n: ------------------------------\n"))
      (command "_.zoom" "_O" ss1 "")
      (sssetfirst nil ss1))
    (princ "\n: ------------------------------\n\t\t*** No previous selection set ***\n: ------------------------------\n")
Edited by 3dwannab
Didn't try it but it seems like you'd need
$M=$(if,$(getvar,cmdactive),_previous,QSPREVIOUS)
for it to work with a command active.
Thanks for the heads up.
What does _previous do?
When a command is active like move or copy _previous (or _P) selects the previous selection.
Your macro runs your lisp command QSPREVIOUS if there's no active command but does nothing if a command is active.
The three macros I posted all work as expected whether a command is active or not.
  • Thanks 1
