mstb Posted April 27, 2022 Share Posted April 27, 2022 hello All I have some questions.These are : Is (ssget "_+.:E:S") == (ssget "_:E:S") ? Is (ssget "_+.:E") == (ssget "_:E") ? Is (ssget "_+.:S") == (ssget "_:E:S") ? Thanks All. Quote Link to comment Share on other sites More sharing options...
Tharwat Posted April 27, 2022 Share Posted April 27, 2022 Here is the help document from Autodesk that explained all about ssget function. http://docs.autodesk.com/ACD/2011/ENU/filesALR/WS1a9193826455f5ff1a32d8d10ebc6b7ccc-693e.htm Quote Link to comment Share on other sites More sharing options...
ronjonp Posted April 27, 2022 Share Posted April 27, 2022 And an even better source http://www.lee-mac.com/ssget.html 3 Quote Link to comment Share on other sites More sharing options...
mstb Posted April 28, 2022 Author Share Posted April 28, 2022 20 hours ago, ronjonp said: And an even better source http://www.lee-mac.com/ssget.html Thanks All I read 2 above source But I still have a problem with "+." I think "+." can use (ssget "_+.:S") == (ssget "_:E:S") And in other cases can be deleted. Or I'm wrong! Quote Link to comment Share on other sites More sharing options...
Stefan BMR Posted April 28, 2022 Share Posted April 28, 2022 (ssget "_+.:S") and (ssget "_:E:S") both simulate the entsel pickbox, but there is a small difference between them: - :E means Everything inside the pickbox, so it's possible to select multiple objects, even if you click just once. - +. means only the top object is selected. The selectionset always contains only 1 object. Quote Link to comment Share on other sites More sharing options...
mstb Posted April 28, 2022 Author Share Posted April 28, 2022 1 hour ago, Stefan BMR said: (ssget "_+.:S") and (ssget "_:E:S") both simulate the entsel pickbox, but there is a small difference between them: - :E means Everything inside the pickbox, so it's possible to select multiple objects, even if you click just once. - +. means only the top object is selected. The selectionset always contains only 1 object. very good Thank you very much. Quote Link to comment Share on other sites More sharing options...
