vertical horizons Posted April 22, 2022 Share Posted April 22, 2022 Is it possible to scale an .ipt (or an .iam) along just the Y Axis? I know that you can go into the drawing and modify it there, but can you SCALE an object in the direction of just ONE axis? Quote Link to comment Share on other sites More sharing options...
TerryDotson Posted April 23, 2022 Share Posted April 23, 2022 Don't know what IPT / IAM is but if it's inside CAD you should be able to make a block of the object, insert that block with the desired Y scale only, then explode it. Beware that polylines with arcs will become elliptical arcs in the process. Quote Link to comment Share on other sites More sharing options...
vertical horizons Posted April 26, 2022 Author Share Posted April 26, 2022 Ipt stands for Inventor Part, and Iam stands for Inventor Assembly. Both of these are 3D features. Quote Link to comment Share on other sites More sharing options...
