bilalntk1 Posted April 19, 2022 Share Posted April 19, 2022 Hi, I have a lot of chainages (around 28 kilometers) in the excel file. I need to put that on polyline in Autocad. please find sample attachments for your ready reference and please help. CHAINAGE.pdf Quote Link to comment Share on other sites More sharing options...
SLW210 Posted April 19, 2022 Share Posted April 19, 2022 No need to make multiple posts in multiple forums. 1 Quote Link to comment Share on other sites More sharing options...
Steven P Posted April 19, 2022 Share Posted April 19, 2022 (edited) So what help do you need? I don't know your skill level and if you have a library of LISPS that you use, so where do we start to help you? For example, starting at the beginning, can you create a LISP routine (doesn't have to be complicated), can you get a routine to reference others, have you got one that can read from excel.... so where do we start to help you? So the first part of your problem, there are a lot of routines out there that will read from an excel file - have you found any of them and can you get your excel data into a variable or a list in a LISP? Then there are chainage LISPs too which will put a marker every so often, either a regular distance or a user specified distance, again have you found any of them? Might be that you just need help combining the 2 together you see. So let us know where to start with the help and I am sure most of us will be happy to give you some snippets of advice, you might get lucky and LISP from someones library that does the same (I have a chainage LISP for example, can't remember where I got it from but that only does a constant distance between points and not a variable one, would need altering a touch) Edit Here: I think this is the piece of code that gets the points along a polyline.. everything else in the LISPs are just doing stuff, but think this is the line you will probably be struggling to find out (setq list_pt (vlax-curve-getPointAtDist obj_vlax total_Chain_distance) ) Edited April 19, 2022 by Steven P 1 Quote Link to comment Share on other sites More sharing options...
Steven P Posted April 19, 2022 Share Posted April 19, 2022 Second comment is how often will you be doing this? If it is a one off thing, or not often, then you can maybe ignore the excel to LISP part, just copy the data and hard code it to this chainage LISP, save a job and source of errors in programming 1 Quote Link to comment Share on other sites More sharing options...
BIGAL Posted April 20, 2022 Share Posted April 20, 2022 Like stevenP lets go back a couple of steps like how are you getting the chainages in the 1st place ? If its pick a point then do just that pick a point and write the chainage label on to the pline. (vla-curve-getclosestpointto obj_vlx pt) To me looks like you have picked specific objects for the PDF. 1 Quote Link to comment Share on other sites More sharing options...
bilalntk1 Posted April 20, 2022 Author Share Posted April 20, 2022 (edited) Sir, I have attached the original excel file and Autocad version for your reference. actually, I need to export (Label) all chainages which are in the excel file, to the alignment in the attached Autocad drawing. 10 hours ago, Steven P said: So what help do you need? I don't know your skill level and if you have a library of LISPS that you use, so where do we start to help you? For example, starting at the beginning, can you create a LISP routine (doesn't have to be complicated), can you get a routine to reference others, have you got one that can read from excel.... so where do we start to help you? So the first part of your problem, there are a lot of routines out there that will read from an excel file - have you found any of them and can you get your excel data into a variable or a list in a LISP? Then there are chainage LISPs too which will put a marker every so often, either a regular distance or a user specified distance, again have you found any of them? Might be that you just need help combining the 2 together you see. So let us know where to start with the help and I am sure most of us will be happy to give you some snippets of advice, you might get lucky and LISP from someones library that does the same (I have a chainage LISP for example, can't remember where I got it from but that only does a constant distance between points and not a variable one, would need altering a touch) Edit Here: I think this is the piece of code that gets the points along a polyline.. everything else in the LISPs are just doing stuff, but think this is the line you will probably be struggling to find out (setq list_pt (vlax-curve-getPointAtDist obj_vlax total_Chain_distance) ) CHAINAGE.xlsx NEED TO LABEL CHAINAGES.dwg Edited April 20, 2022 by bilalntk1 for more clarity Quote Link to comment Share on other sites More sharing options...
Steven P Posted April 20, 2022 Share Posted April 20, 2022 Just quickly with 33 points it might be quicker just to use the measure command as it would be to write, check and verify that a LISP functions correctly. Create a block and use that with measure, use the points above and delete all but the first block inserted for each point and there you go. Obviously if this is something you do regularly it is worth a LISP, will have a think for you. Quote Link to comment Share on other sites More sharing options...
Steven P Posted April 20, 2022 Share Posted April 20, 2022 This one might work, you have to put your points in the list and the points are the distance from the last point So I reckon put these points in the list, to replace line 3: (setq dist_list '( 1017.7673 2150.42 1674.53 797.12 800.1027 725 1235.2773 390.0027 1396.6773 399.05 638.243 587.6797 949.5073 2067.2227 277.5173 511.87 4336.29 1108.44 280.75 1325.0027 426.0951 1135.4422 2099 474.9927 )) Quote Link to comment Share on other sites More sharing options...
Steven P Posted April 20, 2022 Share Posted April 20, 2022 So looking again at this over lunch, it inserts a block named 'tick' - so you will need that in your drawing, and if you have an attribute in that you should be able to modify the code to complete that with the a chainage reference or distance Lee Macs website has info on how to do that, insert the block using the above, then (entlast), sending that to Lees attribute L:ISP and job done. I'll leave it to you to do that part now. 1 Quote Link to comment Share on other sites More sharing options...
BIGAL Posted April 21, 2022 Share Posted April 21, 2022 You did not answer the question how you made the excel in the 1st place was it some other software like GIS. 1 Quote Link to comment Share on other sites More sharing options...
bilalntk1 Posted April 22, 2022 Author Share Posted April 22, 2022 Hi Bigal Sir i made the excel file from "VertexExport" lisp file. please find attached the same. 03_VertexExport.FAS Quote Link to comment Share on other sites More sharing options...
BIGAL Posted April 23, 2022 Share Posted April 23, 2022 Its a fas so useless for us to look at as its compiled. So you picking points in some way so AGAIN why not do the label when you pick a point, it can be either on a pline or a offset point and the square off will be used. Do you really need the Excel ? This is real rough but gives you an idea of how it could be done. Need info like text style and height, correct version writes at 90 to pline. ; sq pt off pline (defun c:wow (obj pt pt2 dist ) (setq obj (vlax-ename->vla-object (car (entsel "Pick obj")))) (setvar 'textstyle "Standard") (while (setq pt (getpoint "\nPick point or Enter to exit ")) (setq pt2 (vlax-curve-getclosestpointto obj pt)) (setq dist (vlax-curve-getdistatpoint obj pt2)) (command "text" pt2 2.5 "" (rtos dist 2 3)) ) (princ) ) 2 Quote Link to comment Share on other sites More sharing options...
devitg Posted April 25, 2022 Share Posted April 25, 2022 On 4/19/2022 at 7:56 AM, bilalntk1 said: Hi, I have a lot of chainages (around 28 kilometers) in the excel file. I need to put that on polyline in Autocad. please find sample attachments for your ready reference and please help. CHAINAGE.pdf 83.37 kB · 7 downloads Please upload the original CHAINAGE .dwg from wher you get this CHAINAGE.pdf as to use it as text size and style model Quote Link to comment Share on other sites More sharing options...
