exceed Posted April 19, 2022 Share Posted April 19, 2022 (edited) ;; inside offset multiple - 2022.04.19 exceed ;; save your drawing. before run this lisp. ;; select object which can offset inside. ;; complex shape will make error. in this case have to run this twice. (vl-load-com) (defun c:flh ( / offdis ss ssl index ent entname obj ) (setq offdis (getdist "\n Input Offset Value = ")) (princ "\n Select Object = ") (setq ss (ssget)) (setq ssl (sslength ss)) (setq index 0) (repeat ssl (setq ent (entget (ssname ss index))) (setq entname (cdr (assoc -1 ent))) (setq obj (vlax-ename->vla-object entname)) (ex_flh obj offdis) (setq index (+ index 1)) ) (princ) ) (defun ex_flh ( obj offdis ) ;/ subloop1 subloop2 subloop1length subloop2length ) (vla-offset obj (* offdis 1)) (setq subloop1 (vlax-ename->vla-object (entlast))) (vla-offset obj (* offdis -1)) (setq subloop2 (vlax-ename->vla-object (entlast))) (setq subloop1type (vlax-get-property subloop1 'entityname)) ;(princ subloop1type) (setq subloop2type (vlax-get-property subloop2 'entityname)) ;(princ "\n") ;(princ subloop2type) (cond ((= subloop1type "AcDbPolyline") (setq subloop1length (vlax-get-property subloop1 'length)) ) ((= subloop1type "AcDbCircle") (setq subloop1length (vlax-get-property subloop1 'Circumference)) ) ((= subloop1type "AcDbArc") (setq subloop1length (vlax-get-property subloop1 'Radius)) ) );end of cond (cond ((= subloop2type "AcDbPolyline") (setq subloop2length (vlax-get-property subloop2 'length)) ) ((= subloop2type "AcDbCircle") (setq subloop2length (vlax-get-property subloop2 'Circumference)) ) ((= subloop2type "AcDbArc") (setq subloop2length (vlax-get-property subloop2 'Radius)) ) );end of cond (cond ((> subloop1length subloop2length) (progn (vla-delete subloop1) (setq looplength subloop2length) (setq obj subloop2))) ((< subloop1length subloop2length) (progn (vla-delete subloop2) (setq looplength subloop1length) (setq obj subloop1))) ((= subloop1length subloop2length) (progn (vla-delete subloop2) (setq looplength subloop1length) (setq obj subloop1))) ) (setq objtype (vlax-get-property obj 'entityname)) (cond ((= objtype "AcDbPolyline") (progn (setq segmentlength '()) (setq startsegment (vlax-curve-getStartParam obj)) (setq endsegment (vlax-curve-getEndParam obj)) (while (< startsegment endsegment) (setq segmentlength (append segmentlength (list (- (vlax-curve-getDistAtParam obj (setq startsegment (1+ startsegment))) (vlax-curve-getDistAtParam obj (1- startsegment)))))) ) ;(princ "\n segmentlength - ") ;(princ segmentlength) (setq minseg (nth 2 (vl-sort segmentlength '>))) (if (> minseg (* offdis 3)) (progn (ex_flh obj offdis)) (progn (princ "\n not enough space ")) );end of if );end of progn ); end of cond case 1 ((= objtype "AcDbCircle") (progn (setq basecircumference (* (* 3 pi) offdis)) (if (> looplength basecircumference) (progn (ex_flh obj offdis)) (progn (princ "\n not enough space ")) );end of if );end of progn ); end of cond case 2 ((= objtype "AcDbArc") (progn (setq baseradius (* 1.5 offdis)) (if (> looplength baseradius) (progn (ex_flh obj offdis)) (progn (princ "\n not enough space ")) );end of if );end of progn ); end of cond case 3 );end of cond ) (princ "\n loading complete") command : FLH experimental lisp. for my study offset executed in both directions, the shorter length is inward, and the longer one is outside = delete. will stop if an appropriate offset value is not entered or if a complex shape is selected. determine whether it can be further offset by the segment length, ex) If the segment length of the created loop is 3, Lisp determines that it can offset 1 on both sides. If not possible, print 'not enough space' and move to the next object. a general shape such as a rectangle or Tetris shape is fine as I tested. but an offset error may occur if the segment length cannot be determined such as that of a flower shape. In that case, just loop stops, so can run it again from within. It would be nice to have a function to +1 to the index variable, move on to the next when an offset error occurs like error control. not judged by segment length. If you have any better Lisp or ideas for this, please let me know. + another way to improve this is to find the offset center points (this point can be multiple) based on these shapes made from outside to inside based on this value, and then offset from inside to outside again. ex) if there is 6, offset by 1 to reach 6->4->2, (this lisp) and find the center point of 2, and offset 1->3->5 again. like this command : RFLH This is more unstable. ;; reverse inside offset multiple - 2022.04.19 exceed ;; save your drawing. before run this lisp. ;; select object which can offset inside. ;; complex shape will make error. in this case have to run this twice. (vl-load-com) (defun c:rflh ( / offdis ss ssl index ent entname obj ) (setq offdis (getdist "\n Input Offset Value = ")) (princ "\n Select Object = ") (setq ss (ssget)) (setq ssl (sslength ss)) (setq index 0) (setq ss2 (ssadd)) (repeat ssl (setq ent (entget (ssname ss index))) (setq entname (cdr (assoc -1 ent))) (setq obj (vlax-ename->vla-object entname)) (setq looplength 0) (setq minseg 0) (setq delta 0) (ex_flh obj offdis) (setq index (+ index 1)) (setq ss2 (ssadd)) ) (princ) ) (defun ex_flh ( obj offdis ) ;/ subloop1 subloop2 subloop1length subloop2length ) (vla-offset obj (* offdis 1)) (setq subloop1 (vlax-ename->vla-object (entlast))) (vla-offset obj (* offdis -1)) (setq subloop2 (vlax-ename->vla-object (entlast))) (setq subloop1type (vlax-get-property subloop1 'entityname)) ;(princ subloop1type) (setq subloop2type (vlax-get-property subloop2 'entityname)) ;(princ "\n") ;(princ subloop2type) (cond ((= subloop1type "AcDbPolyline") (setq subloop1length (vlax-get-property subloop1 'length)) ) ((= subloop1type "AcDbCircle") (setq subloop1length (vlax-get-property subloop1 'Radius)) ) ((= subloop1type "AcDbArc") (setq subloop1length (vlax-get-property subloop1 'Radius)) ) );end of cond (cond ((= subloop2type "AcDbPolyline") (setq subloop2length (vlax-get-property subloop2 'length)) ) ((= subloop2type "AcDbCircle") (setq subloop2length (vlax-get-property subloop2 'Radius)) ) ((= subloop2type "AcDbArc") (setq subloop2length (vlax-get-property subloop2 'Radius)) ) );end of cond (cond ((> subloop1length subloop2length) (progn (vla-delete subloop1) (setq looplength subloop2length) (setq obj subloop2))) ((< subloop1length subloop2length) (progn (vla-delete subloop2) (setq looplength subloop1length) (setq obj subloop1))) ((= subloop1length subloop2length) (progn (vla-delete subloop2) (setq looplength subloop1length) (setq obj subloop1))) ) (ssadd (vlax-vla-object->ename obj) ss2) (setq objtype (vlax-get-property obj 'entityname)) (cond ((= objtype "AcDbPolyline") (progn (setq segmentlength '()) (setq startsegment (vlax-curve-getStartParam obj)) (setq endsegment (vlax-curve-getEndParam obj)) (while (< startsegment endsegment) (setq segmentlength (append segmentlength (list (- (vlax-curve-getDistAtParam obj (setq startsegment (1+ startsegment))) (vlax-curve-getDistAtParam obj (1- startsegment)))))) ) ;(princ "\n segmentlength - ") ;(princ segmentlength) (setq minseg (nth 3 (vl-sort segmentlength '>))) (cond ((> minseg (* offdis 3)) (progn (ex_flh obj offdis)) ); end of cond case 1 ((< minseg (* offdis 3)) (progn (repeat (sslength ss2) (setq obj2 (ssname ss2 0)) (entdel obj2) (ssdel obj2 ss2) ) (setq ss2 (ssadd)) (princ "\n make it reverse ") (setq answer (getstring "\n proceed?")) (setq obj (vlax-ename->vla-object entname)) (setq delta (/ (- (* offdis 3) minseg) 2)) (vla-offset obj (* (- offdis delta) 1)) (setq subloop1 (vlax-ename->vla-object (entlast))) (vla-offset obj (* (- offdis delta) -1)) (setq subloop2 (vlax-ename->vla-object (entlast))) (setq subloop1length (vlax-get-property subloop1 'length)) (setq subloop2length (vlax-get-property subloop2 'length)) (cond ((> subloop1length subloop2length) (progn (vla-delete subloop1) (setq looplength subloop2length) (setq obj subloop2))) ((< subloop1length subloop2length) (progn (vla-delete subloop2) (setq looplength subloop1length) (setq obj subloop1))) ((= subloop1length subloop2length) (progn (vla-delete subloop2) (setq looplength subloop1length) (setq obj subloop1))) ) (ex_flh obj offdis) ); end of progn ); end of cond case2 ((= minseg (* offdis 3)) (progn (vla-offset obj (* offdis 1)) (setq subloop1 (vlax-ename->vla-object (entlast))) (vla-offset obj (* offdis -1)) (setq subloop2 (vlax-ename->vla-object (entlast))) (setq subloop1length (vlax-get-property subloop1 'length)) (setq subloop2length (vlax-get-property subloop2 'length)) (cond ((> subloop1length subloop2length) (progn (vla-delete subloop1) (setq looplength subloop2length) (setq obj subloop2))) ((< subloop1length subloop2length) (progn (vla-delete subloop2) (setq looplength subloop1length) (setq obj subloop1))) ((= subloop1length subloop2length) (progn (vla-delete subloop2) (setq looplength subloop1length) (setq obj subloop1))) ) (princ "\n complete ") );end of progn ); end of cond case3 );end of cond );end of progn ); end of cond case 1 ((= objtype "AcDbCircle") (progn (cond ((> looplength (* offdis 1.5)) (progn (ex_flh obj offdis)) );end of cond case 1 ((< looplength (* offdis 1.5)) (progn (repeat (sslength ss2) (setq obj2 (ssname ss2 0)) (entdel obj2) (ssdel obj2 ss2) ) (setq ss2 (ssadd)) (princ "\n make it reverse ") (setq answer (getstring "\n proceed?")) (setq obj (vlax-ename->vla-object entname)) (setq delta (- (* offdis 1.5) looplength)) (vla-offset obj (* (- offdis delta) 1)) (setq subloop1 (vlax-ename->vla-object (entlast))) (vla-offset obj (* (- offdis delta) -1)) (setq subloop2 (vlax-ename->vla-object (entlast))) (setq subloop1length (vlax-get-property subloop1 'radius)) (setq subloop2length (vlax-get-property subloop2 'radius)) (cond ((> subloop1length subloop2length) (progn (vla-delete subloop1) (setq looplength subloop2length) (setq obj subloop2))) ((< subloop1length subloop2length) (progn (vla-delete subloop2) (setq looplength subloop1length) (setq obj subloop1))) ((= subloop1length subloop2length) (progn (vla-delete subloop2) (setq looplength subloop1length) (setq obj subloop1))) ) (ex_flh obj offdis) );end of progn );end of cond case 2 ((= looplength (* offdis 1.5)) (progn (vla-offset obj (* offdis 1)) (setq subloop1 (vlax-ename->vla-object (entlast))) (vla-offset obj (* offdis -1)) (setq subloop2 (vlax-ename->vla-object (entlast))) (setq subloop1length (vlax-get-property subloop1 'radius)) (setq subloop2length (vlax-get-property subloop2 'radius)) (cond ((> subloop1length subloop2length) (progn (vla-delete subloop1) (setq looplength subloop2length) (setq obj subloop2))) ((< subloop1length subloop2length) (progn (vla-delete subloop2) (setq looplength subloop1length) (setq obj subloop1))) ((= subloop1length subloop2length) (progn (vla-delete subloop2) (setq looplength subloop1length) (setq obj subloop1))) ) (princ "\n complete ") );end of progn ); end of cond case3 );end of cond );end of progn ); end of cond case 2 ((= objtype "AcDbArc") (progn (cond ((> looplength (* offdis 1.5)) (progn (ex_flh obj offdis)) );end of cond case 1 ((< looplength (* offdis 1.5)) (progn (repeat (sslength ss2) (setq obj2 (ssname ss2 0)) (entdel obj2) (ssdel obj2 ss2) ) (setq ss2 (ssadd)) (princ "\n make it reverse ") (setq answer (getstring "\n proceed?")) (setq obj (vlax-ename->vla-object entname)) (setq delta (- (* offdis 1.5) looplength)) (vla-offset obj (* (- offdis delta) 1)) (setq subloop1 (vlax-ename->vla-object (entlast))) (vla-offset obj (* (- offdis delta) -1)) (setq subloop2 (vlax-ename->vla-object (entlast))) (setq subloop1length (vlax-get-property subloop1 'radius)) (setq subloop2length (vlax-get-property subloop2 'radius)) (cond ((> subloop1length subloop2length) (progn (vla-delete subloop1) (setq looplength subloop2length) (setq obj subloop2))) ((< subloop1length subloop2length) (progn (vla-delete subloop2) (setq looplength subloop1length) (setq obj subloop1))) ((= subloop1length subloop2length) (progn (vla-delete subloop2) (setq looplength subloop1length) (setq obj subloop1))) ) (ex_flh obj offdis) );end of progn );end of cond case 2 ((= looplength (* offdis 1.5)) (progn (vla-offset obj (* offdis 1)) (setq subloop1 (vlax-ename->vla-object (entlast))) (vla-offset obj (* offdis -1)) (setq subloop2 (vlax-ename->vla-object (entlast))) (setq subloop1length (vlax-get-property subloop1 'radius)) (setq subloop2length (vlax-get-property subloop2 'radius)) (cond ((> subloop1length subloop2length) (progn (vla-delete subloop1) (setq looplength subloop2length) (setq obj subloop2))) ((< subloop1length subloop2length) (progn (vla-delete subloop2) (setq looplength subloop1length) (setq obj subloop1))) ((= subloop1length subloop2length) (progn (vla-delete subloop2) (setq looplength subloop1length) (setq obj subloop1))) ) (princ "\n complete ") );end of progn ); end of cond case3 );end of cond );end of progn ); end of cond case 3 );end of cond ) (princ "\n loading complete") Edited April 19, 2022 by exceed add case of arc Quote Link to comment Share on other sites More sharing options...
