BIGAL Posted April 15, 2022 Share Posted April 15, 2022 Hi I have been using the Notepad++ run lisp extension for ages and its stopped working after installing an upgrade, I tried going to the web site link https://sourceforge.net/projects/nppactivexplugin/ and have just gone around in circles trying to join so could send a message re problem, is anyone else having problems ? Do you have a sourceforge account and could send a message would be appreciated. ; This routine runs the code in the active editor of NotePad++ from AutoCAD: (defun C:n++ nil (C:RunFromNotePadPP)) ; Quick Run (defun C:RunFromNotePadPP ( / scr *error* err np++ npeditor npSS npMS r ) ; NOTE: Requires ActiveX plugin(by David Gausmann) installed on the NP++ ; https://sourceforge.net/projects/nppactivexplugin/ (defun *error* (m) (foreach x (reverse (list np++ npeditor npSS npMS)) (vl-catch-all-apply (function vlax-release-object) (list x)) ) (gc) (gc) (and msg (or (wcmatch (strcase msg) "*BREAK,*CANCEL*,*EXIT*") (princ (strcat "\nError: " msg)))) (princ) ); defun *error* (setq err (vl-catch-all-apply (function (lambda nil ; THIS WORKS - IT GETS THE ACTIVE DOCUMENT CODE IN NOTEPAD !!! (setq np++ (vlax-get-or-create-object "NotepadPlusPlus.Application")) (setq npeditor (vlax-get np++ 'ActiveEditor)) (vlax-invoke-method npeditor 'selectAll) (setq npSS (vlax-get npeditor 'selections)) (setq npMS (vlax-get npSS 'mainSelection)) (setq r (vlax-get-property npMS 'text)) (vlax-invoke npSS 'setRange 0 0 0 0) ); lambda ); function ); vl-catch-all-apply ); setq err (*error* nil)(princ) (if (and r (not (vl-catch-all-error-p err))) (eval (read (strcat "(list\n" r "\n)"))) ) ); defun Quote Link to comment Share on other sites More sharing options...
lido Posted April 15, 2022 Share Posted April 15, 2022 Did you register the plugin? Quote Link to comment Share on other sites More sharing options...
BIGAL Posted April 16, 2022 Author Share Posted April 16, 2022 i have been using every day for years just turned off after last Notepad++ update, I have lodged a ticket at Sourceforge. Was wondering if anybody else has had the problem. Uninstalled and reinstalled plugin no go Bricscad and Autocad. Quote Link to comment Share on other sites More sharing options...
abra-CAD-abra Posted April 19, 2022 Share Posted April 19, 2022 BIGAL, I just tried this using the following (portable) version: npp.8.2.1.portable.x64 It works fine. Out of interest, what do you use it for? Is it to execute scripting language on NP++ files or other files (*.dwg), or both? This post has plunged me into the NP++ plugin world! Thanks BIGAL Quote Link to comment Share on other sites More sharing options...
BIGAL Posted April 20, 2022 Author Share Posted April 20, 2022 (edited) I use it to code and run Lisp from N++ you can make your test code as big or break it into little code segments as needed. The closing bracket check is a great help. I did get a response from David @ Sourceforge, awaiting some further comment. Edited April 20, 2022 by BIGAL Quote Link to comment Share on other sites More sharing options...
abra-CAD-abra Posted April 20, 2022 Share Posted April 20, 2022 I have used NP++ for a while now but never really looked at the plugins. I have installed a few now, including the brackets check plugin. The N++ function you shared above is really useful - I can see why you are keen to get this plugin working again Quote Link to comment Share on other sites More sharing options...
BIGAL Posted April 21, 2022 Author Share Posted April 21, 2022 Load "Compare" plugin its really handy use with entget when changing 1 variable and trying to find dxf numbers. Same with setvar. use replace ") (" with ")\r(" when comparing entgets. 1 Quote Link to comment Share on other sites More sharing options...
