mrstauffer Posted February 13, 2009 Posted February 13, 2009 I am wanting to create a custom command that will scale a drawing up 25.4 and zoom Extents. The following script file works but I would like it to be a command line command. scale all 0,0,0 25.4 Zoom E. I have tried to use the customize user interface but have had no luck. I keep getting "unknown command". Quote
lpseifert Posted February 13, 2009 Posted February 13, 2009 (defun c:sc254 () (setq old_tile (getvar "tilemode")) (setvar "tilemode" 1) (command "scale" "all" "" "0,0" 25.4) (command "zoom" "extents") (setvar "tilemode" old_tile) (princ) ) Quote
CarlB Posted February 13, 2009 Posted February 13, 2009 Hey how did you edit your post without it showing as edited, I was going to point out some code modifications, but then sudenly the code was revised/corrected Quote
JohnM Posted February 13, 2009 Posted February 13, 2009 ;;; in lisp (defun c:scmm () (command "scale" "all" "" "0,0" 25.4) (command "zoom" "e") );_defun ;;; macro for a button ^C^Cscale;all;;0,0;25.4;zoom;e; Quote
brawleyman Posted February 13, 2009 Posted February 13, 2009 I am wanting to create a custom command that will scale a drawing up 25.4 and zoom Extents. The following script file works but I would like it to be a command line command. scale all 0,0,0 25.4 Zoom E. I have tried to use the customize user interface but have had no luck. I keep getting "unknown command". Here it is in MACRO form so that you can create a custom button for it. I tested it in ACAD 09 and it worked just fine. ^C^C^PScale;all;;0,0;25.4;^C^Czoom;e; Or, if you are familiar with LISP I can create a routine for you. Hope that helps! Quote
lpseifert Posted February 13, 2009 Posted February 13, 2009 Hey how did you edit your post without it showing as edited, I was going to point out some code modifications, but then sudenly the code was revised/corrected I was a bit hasty, I typed it in the forum. Then I cut/pasted into Vlide, saw my mistakes, deleted the post, then reposted. BTW... I think you can edit a post w/o it showing as edited so long as you don't leave the forum Quote
Lee Mac Posted February 13, 2009 Posted February 13, 2009 I was a bit hasty, I typed it in the forum. Then I cut/pasted into Vlide, saw my mistakes, deleted the post, then reposted. Blimey... you did all that in the time that Carl spotted the mistakes! ~ you are hasty indeed Quote
lpseifert Posted February 13, 2009 Posted February 13, 2009 anything to prevent actually working... Friday Quote
brawleyman Posted February 13, 2009 Posted February 13, 2009 anything to prevent actually working... Friday I second that. Here in a few hours, I get to play putt-putt to leave 2 hours early. Wish every day were a Friday... Quote
mrstauffer Posted February 13, 2009 Author Posted February 13, 2009 Thanks all. I will try these out when time permits. YES, it's Friday!!! Quote
uddfl Posted February 13, 2009 Posted February 13, 2009 anything to prevent actually working... FridayLOL looks like there's several of us... Quote
mrstauffer Posted February 13, 2009 Author Posted February 13, 2009 Here it is in MACRO form so that you can create a custom button for it. I tested it in ACAD 09 and it worked just fine. ^C^C^PScale;all;;0,0;25.4;^C^Czoom;e; Or, if you are familiar with LISP I can create a routine for you. Hope that helps! The button version is exactly what I was looking for. Quote
