How to Select polyline by attribute
Hi all just want to know How to Select polyline by attribute, like in this screenshot i want to select span id
Use QUICKSELECT, which you will find in your right click menu,
or go old school and use the FILTER command.
QUICK SELECT is appreciably more user friendly, and likely
do exactly what you want it to, after defining your search parameters.
Yet another option would be SELECT SIMILAR, also found in your right click menu.  :beard:
If you were to add the Handle to your attributes then its easy. You can get a entity using its handle id.
No this method i already try, because that was polyline that's why
Actually, those are already done by out client i just import those from shp file to AutoCAD map
Sounds like OD object data if your importing shp files from GIS etc, lots of examples about using OD. Need a dwg to look further.
