CombineValues
mousho
hello guys
i have a great lisp that i found in the website for combinning values
anyone can help me to change it from single selection (entsel) to selection by window (ssget)
i try few times with no success
CombineValues.LSP
That's going to take more then just switching out (entsel)
I'm guessing you just want the total sum? lisp was edited from here
*text must be only numbers or it will be ignored.
(defun C:TXTSUM (/ sum ss en txt sumtxt)
  (princ "\nSelect Text to get Sum:")
  (setq sum 0)
  (if (and (setq ss (ssget '((0 . "*TEXT")))) (> (sslength ss) 1))
      (foreach en (vl-remove-if 'listp (mapcar 'cadr (ssnamex SS)))
        (setq txt (cdr (assoc 1 (entget en))))
        (if (distof txt)
          (setq sumtxt (rtos (setq sum (+ (atof txt) sum)) 2 (getvar "dimdec")))
            (setq txt (LM:parsenumbers txt))
            (foreach num txt
              (setq sumtxt (rtos (setq sum (+ num sum)) 2 (getvar "dimdec")))
      (prompt (strcat "\nTotal Sum: " sumtxt))
;; Parse Numbers  -  Lee Mac
;; Parses a list of numerical values from a supplied string.
;;  Author: Lee Mac, Copyright © 2013 - www.lee-mac.com       ;;
(defun LM:parsenumbers (str)
  ((lambda (l)
           (read
             (strcat "("
                     (vl-list->string
                       (mapcar
                         '(lambda (a b c)
                                  (if (or (< 47 b 58)
                                          (and (= 45 b) (< 47 c 58) (not (< 47 a 58)))
                                          (and (= 46 b) (< 47 a 58) (< 47 c 58))
                                    b 32
                         (cons nil l) l (append (cdr l) '(()))
    (vl-string->list str)
Edited by mhupp
Code Updated
(defun C:TXTSUM (/ elist en ss sum sumtxt txt ins)
  (setq sum 0)
        (setq elist (entget en))
        (setq txt (cdr (assoc 1 elist)))
THX
But the other lisp is reading from xref and its very helpfull
Yes it is. You cant do ssget with nested items.
But you can explore it as if it is a block reference. ;)
Yes or go into edit mode would be better
  • Agree 1
You can get the numbers from a string. eg "area = 1224"
(defun LM:parsenumbers ( str )
    (   (lambda ( l )
            (read
                (strcat "("
                    (vl-list->string
                        (mapcar
                           '(lambda ( a b c )
                                (if (or (< 47 b 58)
                                    b 32
On 4/10/2022 at 7:08 AM, mousho said:
THX
So your going to have to either copy the xref to a new location and explode it or enter into edit mode.
If it doesn't have any other blocks inside. You can then select all of the text you want and run the lisp to get a total sum.
Added Lee Mac's code to what i had above.
This is one of the cheat for converting code written in entsel to ssget.
(defun c:ssgetentsel ()
  (setq exss (ssget))
  (setq exssl (sslength exss))
  (setq exssindex 0)
  (repeat exssl
    (setq exssent (entget (ssname exss exssindex)))
    (setq makeentsel1 (cdr (car exssent)))
    (setq makeentsel2 (cdr (assoc 10 exssent)))
    (setq makeentsel (list makeentsel1 makeentsel2))
    (princ makeentsel) ; do something
    (setq exssindex (+ exssindex 1))
And you can access the object in the block with the nametolist and while statements here.
Get your text from there.
I used this for my make it color Lisp, but it gave me a headache.
It would be better to solve it with other people's solutions above.
However, since it is difficult to select the target text from a block or xref,
the solutions of others above seem more appropriate.
(or can be easy if the text has a specific prefix or suffix attached to it)
Edited by exceed
