CyberAngel Posted April 7, 2022 Share Posted April 7, 2022 (edited) I have a storm drainage network that someone designed in Civil 3D 2021. Now I'm doing the as-built drawings, so I need to adjust the locations and inverts of the structures. When I try to adjust the sumps for some of the structures, they go to a certain elevation but no lower. I changed the sump behavior to Depth and Elevation, but neither method works properly. I can physically pull down the sump on the profile, but it doesn't change the data or the representation. Someone online suggested swapping out the structure for a different part and then swapping back to reset the sump. Here's where the other problem cropped up. When I pull up the list of parts, most of them are missing. When I check my parts list, they're all there, but the missing ones can't be edited; instead there's a message, "Required pipe network catalog(s) not set." The engineer who designed the network thinks it's a bug in Civil 3D 2022, because he can swap the part in 2021 without an issue. Has anyone else come across this problem? Is there a work-around? I'm going to have IT install 2021 on my system, but if it's a bug, someone at Autodesk needs to address it moving forward. Edit: I can't delete the structure and create a new one, for the same reason I can't swap: the part isn't available. Also it would be nice if they addressed the original issue with the sumps. Edited April 7, 2022 by CyberAngel Quote Link to comment Share on other sites More sharing options...
BIGAL Posted April 9, 2022 Share Posted April 9, 2022 I dont know if IMPORTSTYLESANDSETTINGS will help. Quote Link to comment Share on other sites More sharing options...
