Hello everybody! I would like to receive some kind of help in order to get an LISP program that can edit/modify regions, I have been searching out about this but it is impossible to find something like that. Please anybody that can help me? Thank you in advanced!
I know that you know what you want. that description gives us nothing to work with.
Either be more detailed in what your looking to do with the lisp  or upload a sample drawing with a before and after.
or both.
Edited by mhupp
or both.
Thank you for replying. Well as you may know region in AutoCAD are imposible of modifying, the only action that you can do to do this, is going to the 3d view model option, but takes a lot of time to changes model options, mainly if you have to do this modification on many region AutoCAD. Thank you in advanced
modifications like ...
explode
join bits into polyline
edit polyline how you want it
region polyline
explode
region polyline
Ok, what I need is to do what is easy to do in a closed polyline (move its vertex with no problems). So for instance, region has vertex also, however they are no easy to move without exploding the region. The main idea is to have to modify region without exploding and again creating the region, and without going to 3d view models in AutoCAD. Thank you again for your answers!
Edited by wil3000
