Casusa Posted March 31, 2022 Share Posted March 31, 2022 Hi. How to solve this error? Thanks. Quote Link to comment Share on other sites More sharing options...
Dana W Posted March 31, 2022 Share Posted March 31, 2022 Click the check box then click OK. OR If you want to skip over the signature stuff, click cancel Quote Link to comment Share on other sites More sharing options...
Casusa Posted April 1, 2022 Author Share Posted April 1, 2022 13 hours ago, Dana W said: Click the check box then click OK. OR If you want to skip over the signature stuff, click cancel It doesn't work either way. This happens when I click on any drawing inside a windows folder!! Quote Link to comment Share on other sites More sharing options...
CyberAngel Posted April 1, 2022 Share Posted April 1, 2022 3 hours ago, Casusa said: It doesn't work either way. This happens when I click on any drawing inside a windows folder!! Well, there's your problem. Open AutoCAD first, then open the drawing from within the app. When you open a drawing via the operating system, things happen that you may not want. 1 Quote Link to comment Share on other sites More sharing options...
Casusa Posted April 1, 2022 Author Share Posted April 1, 2022 2 minutes ago, CyberAngel said: Well, there's your problem. Open AutoCAD first, then open the drawing from within the app. When you open a drawing via the operating system, things happen that you may not want. Anything new? Thanks. Quote Link to comment Share on other sites More sharing options...
Cad64 Posted April 2, 2022 Share Posted April 2, 2022 Give this a try: https://knowledge.autodesk.com/support/autocad/learn-explore/caas/sfdcarticles/sfdcarticles/Digital-Signatures-icon-disabled-by-default.html Quote Link to comment Share on other sites More sharing options...
Casusa Posted April 7, 2022 Author Share Posted April 7, 2022 On 4/2/2022 at 7:15 PM, Cad64 said: Give this a try: https://knowledge.autodesk.com/support/autocad/learn-explore/caas/sfdcarticles/sfdcarticles/Digital-Signatures-icon-disabled-by-default.html It doesn't work. I've tried that also. Quote Link to comment Share on other sites More sharing options...
