B.N. Posted March 30, 2022 Posted March 30, 2022 Hello, I have plans where there are different lines (different layers) overlapping. Can it be visualized? either by offsetting the overlapping lines or something like a overlap counter? Other solutions may be provided! Drawing1.dwgFetching info... Quote
B.N. Posted March 30, 2022 Author Posted March 30, 2022 On 3/30/2022 at 10:19 AM, exceed said: how about to use basic command OVERKILL Expand I don't want to delete nor change the layer. I want to see the separate lines or see how much lines are overlapping Quote
marko_ribar Posted March 30, 2022 Posted March 30, 2022 Here is something you could play with (draworder versions are the ones I supposed you are looking for...) : http://www.theswamp.org/index.php?topic=57461.0 (You'll have to be logged to theswamp.org to access...) 1 Quote
