Hi
Is anyone able to make the attched dwg into dynamic blocks, i would like to be able to rotate them (0, 90, 180, 270,360) but the lettering remains vertical, stretch them and also select the scale from a drop down box.
I have tried but just cant achieve what im after.
Any help much appreciated
Paul
Drawing1.dwg
You only need 1 visibilty state as you can use a stretch parameter on the block it would pull the top, left and right based on scale. Your welcome to use Multi radio buttons.lsp to choose the scale, you need Lee-mac dynamic block lisp as well to set the parameters to new value. You will need the ratio for the scales 1:10 is not 2 x 1:5. Run the Multi radios twice scale then rotation. The rotation maybe just that rotate.
A 2column version also
Multi radio buttons 2col.lsp
Edited by BIGAL
