Lisp for total line length for lines which in every separately box
Hi Everyone,
I want to make this with lisp in Autocad...
I want to export totale line lenght to excel table..
but i want to see lenght of lines with their box name with lenght..
Pls see example in attachment,
Can you help me pls this issue
@mssoysal  For better understanding, and  maybe get further help, please upload such sample.dwg
As far as I know, ACAD only can edit DWG.
 Or send it to devitg@gmail.com
Expand
Hi Devitg;
Pls find sample document with attachment...
Thank you so much
Autocad Lisp.rarFetching info...
;;; Source : https://www.cadtutor.net/forum/topic/74677-lisp-for-total-line-length-for-lines-which-in-every-separately-box/?do=findComment&comment=591483
;;; REMOVE DUPLICATES - NON RECURSIVE NON COMMAND FUNCTION ;;;
(setq lst '("box1" "box1" "box1" "box2" "box2" "box3" "box3"))
(defun mr_RemoveDupl (InList fuzz / x r )
  (while (setq x (car InList))
    (setq InList
      (vl-remove-if
        (function
          (lambda ( y )
            (equal x y fuzz)
        ) InList
    (setq r (append r (list x)))
(mr_RemoveDupl lst 0) => ("box1" "box2" "box3")
(defun mr_RemoveDupl (InList fuzz)
  (vl-remove-if-not
    (function
      (lambda ( x )
        (if
          (vl-some
            (function
              (lambda ( y )
                (equal x y fuzz)
            ) InList
            (setq InList
              (vl-remove-if
                (function
                  (lambda ( y )
                    (equal x y fuzz)
                ) InList
            x
    ) InList
(setq rtn
  (vl-sort
    (setq lst
      (vl-remove nil
        (mapcar
          (function
            (lambda ( x / r )
              (if
                (vl-some
                  (function
                    (lambda ( y )
                      (equal x y)
                  ) lst
                  (setq lst
                    (vl-remove-if
                      (function
                        (lambda ( z )
                          (equal x z)
                      ) lst
                  x
          ) lst
    (function
      (lambda ( a b )
        (< (atoi a) (atoi b))
rtn => ("box1" "box2" "box3")
Create pseudo code :
1. Select all rectangles...
2. Iterate through selection set...
3. Foreach rectangle :
  * 1. Select all entities inside - [ curve entities / have lenghts : (vlax-curve-getdistatparam curve (vlax-curve-getendparam curve)) ]
  * 2. Foreach curve :
      * create/append association list (rectangle-description / curve-length ^^^ look above ^^^)
4. Look into this topic to learn how to quickly create TABLE enitity from data stored in LIST (association list - previously built)
https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/table-editing/m-p/9335975
5. Insert 2 tables - like you wanted...
For first one :
for ex. :
(setq assoclst '(("box1" 15) ("box1" 20) ("box1" 50) ("box2" 30) ("box2" 20) ("box3" 25) ("box3" 12)))
(setq rtn
  (vl-sort assoclst
    (function
      (lambda ( a b )
        (< (atoi (car a)) (atoi (car b)))
rtn => (("box1" 15) ("box1" 20) ("box1" 50) ("box2" 30) ("box2" 20) ("box3" 25) ("box3" 12))
For second one - you'll have to summarize lengths foreach parent rectangle :
for ex. :
(setq rtn
  (vl-sort
    (vl-remove nil
      (mapcar
        (function
          (lambda ( x / r )
            (if
              (and
                (setq r
                  (apply (function +)
                    (mapcar (function cadr)
                      (vl-remove-if-not
                        (function
                          (lambda ( y )
                            (equal (car x) (car y))
                          (or
                            lst
                            (setq lst assoclst)
                          lst
                (assoc (car x) lst)
                (setq lst
                  (vl-remove-if
                    (function
                      (lambda ( z )
                        (equal (car x) (car z))
                    ) lst
              (list (car x) r)
        ) assoclst
    (function
      (lambda ( a b )
rtn => (("box1" 85) ("box2" 50) ("box3" 37))
Edited by marko_ribar
    (setq InList
      (vl-remove-if
        (function
          (lambda ( y )
            (equal x y fuzz)
        ) InList
  (vl-remove-if-not
    (function
      (lambda ( x )
        (if
          (vl-some
            (function
              (lambda ( y )
                (equal x y fuzz)
            ) InList
            (setq InList
              (vl-remove-if
                (function
                  (lambda ( y )
                    (equal x y fuzz)
                ) InList
            x
    ) InList
(setq rtn
  (vl-sort
    (setq lst
      (vl-remove nil
        (mapcar
          (function
            (lambda ( x / r )
              (if
                (vl-some
                  (function
                    (lambda ( y )
                      (equal x y)
                  ) lst
                  (setq lst
                    (vl-remove-if
                      (function
                        (lambda ( z )
                          (equal x z)
                      ) lst
                  x
          ) lst
    (function
      (lambda ( a b )
For first one :
for ex. :
(setq rtn
  (vl-sort assoclst
    (function
      (lambda ( a b )
for ex. :
(setq rtn
  (vl-sort
    (vl-remove nil
      (mapcar
        (function
          (lambda ( x / r )
            (if
              (and
                (setq r
                  (apply (function +)
                      (vl-remove-if-not
                        (function
                          (lambda ( y )
                          (or
                            lst
                            (setq lst assoclst)
                          lst
                (assoc (car x) lst)
                (setq lst
                  (vl-remove-if
                    (function
                      (lambda ( z )
                    ) lst
              (list (car x) r)
        ) assoclst
    (function
      (lambda ( a b )
Expand
Thanks Marko_ribar..
But I didnt open lisp.. It error Bad function Type - "box1"..
But I want to draw table in excel.. not in the cad? Your code draw table in cad i think?
