VBA - How can I hide all layers of an AutoCAD drawing?
Hi,
I'm making a macro in VBA for AutoCAD.
How can I hide all layers present in a drawing of AutoCAD?
There is an instuction, command or method? :?
And after that, how can I show a layer called "Pippo"?
Thanks,
Marc
If you have express tools installed you should look into the layiso and layunison commands. Also in autocad the layon and layoff commands
or layer2 tool bar, which can isolate layers or turn them off
so like
(carnt remember the coammand name)
(command "layeriso" "pippo" \)
this should point you in right direction
for each acadlayer in thisdrawing.layers
layer.freeze=true
next
layer.item('Pippo").freeze=false
