lisp for Add vertex on intersecting 3d polyline with elevation
MOHITGAUR
This lisp not work all the time (Specially large lines) but when selecting both line (One long 3dpolyline and one vertical 3Dpolyline), its gives us vertex on small vertical line.
Could you take a look again please?
I need vertex on each 3Dpolylines intersection with interpolate elevation in batch mode.
Please refer attached image after lisp result.
Thanks to give your valuable time.
Hello, add this code in the file and try with command "dd2". It work with 3dpoly intersect but only if they are with the same elevation. With interpolation will be hard for me and if someone else want can change the code, will be better.
(defun c:dd2 ( / sset intt ssel2)
(setq sset (ssget (list (cons 0 "*POLYLINE"))))
(setq lst (LM:intersectionsinset sset))
(setq ssel2 (VaniVL sset "Try13"))
(vlax-for x ssel2
	(T:InVert x lst)
Thanks Trudy for your time and effort. But this lisp also not working properly.
2 3D polylines are intersect with each other without vertex, so become same elevation for both lines not possible.
Thanks
@MOHITGAUR did you try the new uploaded lisp, from this post.
In the second post i modify some things and i think, it work.
Okay nvm, try this xD
Again with "dd2"
Edited by Trudy
I fount the problem.
When you zoom to max you will se you have multiple intersect point for each line and for some very short distance you have around 6-7 int points. I will modify it tomorrow but dont think this is what you need.
