Ish Posted March 11, 2022 Share Posted March 11, 2022 2 hours ago, BIGAL said: Either of these versions will hatch this if its 2 plines. For Sandeep RC if your confident that all the areas are closed in some way either version will work, I exploded the plines so it was all lines and worked fine. ; hatch boundary's ; By AlanH Mar 2022 (defun c:lothatch1 ( / ss x ang ent pt) (setq ss (ssget (list (cons 0 "*TEXT")))) (setq ang 0.0) (setvar 'HPSCALE 5.0) (setvar 'hpname "Ansi31") (repeat (setq x (sslength ss)) (setq pt (cdr (assoc 10 (entget (ssname ss (setq x (1- x))))))) (command "bpoly" pt "") (setq ent (entlast)) (setvar 'hpang ang) (command "-hatch" "S" ent "" "") (setq ang (+ ang 0.25)) (entdel ent) ) (princ) ) (defun c:lothatch2 ( / ss x ang ent pt) (setq ss (ssget (list (cons 0 "*TEXT")))) (setq ang 0.0) (setvar 'HPSCALE 5.0) (setvar 'hpname "Ansi31") (repeat (setq x (sslength ss)) (setq pt (cdr (assoc 10 (entget (ssname ss (setq x (1- x))))))) (setvar 'hpang ang) (command "-hatch" pt "" "") (setq ang (+ ang 0.25)) ; radians ) (princ) ) This is best, working on text and mtext , closed polyline, non close pline. Quote Link to comment Share on other sites More sharing options...
