BRIAM RAMON Posted March 3, 2022 Share Posted March 3, 2022 (edited) I would like to merge the lisps I show at the end into one, where the process is first ADDID.lsp and then OD2ATT.lsp If it were possible with your help to add a new functionality to addid.lsp and that is that when you copy the block name in the TIPO_SENAL field of the Object Data You can check the block name to be able to change it to another, with some examples it would be enough to add as many times as this operation is necessary. thank you very much, greetings .... (defun c:ADDID (/ n inc enam idd efn) (setq tn "SDM_SEN_SENALIZACION") (prompt "Seleccionar señales") (princ) (setq n (getint "\n Ingrese valor de Inicio: ") ss (ssget '((0 . "insert"))) ) (setq inc 0) (repeat (setq len (sslength ss)) (setq enam (ssname ss inc)) (setq idd (itoa n)) (setq efn(vla-get-effectivename(vlax-ename->vla-object enam))) (ade_odaddrecord enam tn) (ade_odsetfield enam tn "INTERNO_SENAL" 0 n) (ade_odsetfield enam tn "TIPO_SENAL" 0 efn) (command "chprop" enam "" "c" "ByLAyer" "") (setq inc (1+ inc) n (1+ n) ) ) (alert "The entities selected with INTERNO_SENAL were updated") (princ) ) .... (defun c:OD2ATT (/ ss) (vl-load-com) (if (setq ss (ssget '((0 . "INSERT") (2 . "`*U*")))) ((lambda (i / e s od r v n d tag) (while (setq e (ssname ss (setq i (1+ i)))) ;; Extract object data (setq b (ade_odgetfield e (setq od (car (ade_odgettables e))) "INTERNO_SENAL" 0)) ;; Populate attributes (if (and (setq n (vla-get-effectivename (setq v (vlax-ename->vla-object e)))) (setq d (vla-item (vla-get-blocks (vla-get-activedocument (vlax-get-acad-object))) n))) (foreach attrib (vlax-invoke v 'getattributes) (vlax-for item d (if (= (vla-get-objectname item) "AcDbAttributeDefinition") (if (= (vla-get-tagstring attrib) (vla-get-tagstring item)) (cond ((= "INTERNO" (setq tag (vla-get-tagstring item))) (vla-put-textstring attrib b)))))))) )) -1)) (princ)) ADDID.lsp OD2ATT.lsp eg.dwg Edited March 3, 2022 by BRIAM RAMON Quote Link to comment Share on other sites More sharing options...
BRIAM RAMON Posted March 23, 2022 Author Share Posted March 23, 2022 I was able to join the routines in a lisp, I just need to include the function to check the nam e of the block before copying it to the OD, I share the .lsp regards!ADDID_OD2ATT.lsp Quote Link to comment Share on other sites More sharing options...
