mac26 Posted March 2, 2022 Share Posted March 2, 2022 Below is the code snippet that has me scratching my head. When the routine executes the "-insert" command all goes will until it is supposed to evaluate the three attributes, at that point it crashes. This is what is shown at the command line: (2.90716e+06 794227.0)-insert Enter block name or [?] <Map_Survey_Point>: Map_Survey_Point. If I do this:(command "-insert" "Map_Survey_Point" x_y "" "" "" it will ask for the three attributes and if I put in the variables it will insert the block with the variable names not the values. I have done this many times before in different applications and it has always worked. Here are the results of the lst setq: _$ lst (89 2.90716e+06 794227.0 45.04 BLDGCOR) _$ desc BLDGCOR _$ elev 45.04 _$ pntnum 89 any help would be appreciated. thanks (setq lst (read (strcat "(" d ")")) pntnum (nth 0 lst) x (nth 1 lst) y (nth 2 lst) elev (nth 3 lst) desc (nth 4 lst) x_y (list x y) ) (command "-insert" "Map_Survey_Point" x_y "" "" "" desc elev pntnum) Quote Link to comment Share on other sites More sharing options...
Trudy Posted March 2, 2022 Share Posted March 2, 2022 can you Upload .dwg file with the block Quote Link to comment Share on other sites More sharing options...
mhupp Posted March 2, 2022 Share Posted March 2, 2022 might be how your building your list from d (setq pntnum (nth 0 d) x (nth 1 d) y (nth 2 d) elev (nth 3 d) desc (nth 4 d) ) (command "-insert" "Map_Survey_Point" (list x y) "" "" "" desc elev pntnum) Quote Link to comment Share on other sites More sharing options...
Steven P Posted March 2, 2022 Share Posted March 2, 2022 If I was checking this I would look at your (command "-insert" "Map_Survey_Point" x_y "" "" "" desc elev pntnum) line Perhaps print to screen everything it is saying - you have probably done this? and then you can see what it is doing a bit more clearly something like (princ "\n x_y: ") (princ x_y) (princ "\n desc: ") (princ desc) (princ "\n elev: ") (princ elev) (princ "\n pntnum: ") (princ pntnum) (princ "\n") Also might be worth a check that the block is loaded into the drawing file too - probably is of course, but as an error check (if (tblsearch "block" "Map_Survey_Point") (progn (princ "Yes - So Do Something") ) ;end progn (princ "Block doesn't exist in this drawing") ) ; end if I put this together just to check (defun c:testthis ( / ) (setq MyBlock "Map_Survey_Point") (setq lst (list 89 2.90716e+06 794227.0 45.04 BLDGCOR)) (setq pntnum (nth 0 lst) x (nth 1 lst) y (nth 2 lst) elev (nth 3 lst) desc (nth 4 lst) x_y (list x y) ) (princ "\n x_y: ") (princ x_y) (princ "\n desc: ") (princ desc) (princ "\n elev: ") (princ elev) (princ "\n pntnum: ") (princ pntnum) (if (tblsearch "block" MyBlock) (progn (command "-insert" MyBlock x_y "" "" "" desc elev pntnum) ) ;end progn (princ "Block doesn't exist in this drawing") ) ; end if ) The only thing it isn't checking is how you make lst.. and if it doesn't work then that is your problem 1 Quote Link to comment Share on other sites More sharing options...
Steven P Posted March 2, 2022 Share Posted March 2, 2022 (Oh, not sure about your block I tried this with a fairly basic block, not dynamic or anything and (command "-insert" ....) only wants block name, insert point, X scale, Y scale and rotation, doesn't want desc, elev and pntnum - AutoCAD 2022, BricsCAD and others might be different) Quote Link to comment Share on other sites More sharing options...
mhupp Posted March 2, 2022 Share Posted March 2, 2022 If you insert a block with attributes it should prompt what to input for each attribute. Prompt <Value>: Test 1 Quote Link to comment Share on other sites More sharing options...
BIGAL Posted March 2, 2022 Share Posted March 2, 2022 Do you have 3 or more attributes in your block ? Without dwg no idea. Quote Link to comment Share on other sites More sharing options...
Steven P Posted March 3, 2022 Share Posted March 3, 2022 11 hours ago, mhupp said: If you insert a block with attributes it should prompt what to input for each attribute. Prompt <Value>: Test Thanks MHUPP, I just used a very simple block from a drawing I had loaded Quote Link to comment Share on other sites More sharing options...
ronjonp Posted March 3, 2022 Share Posted March 3, 2022 Another way to do this is set ATTREQ to 0 then fill in the attributes after insertion: (defun _putatt (e tag val) (vl-catch-all-apply 'setpropertyvalue (list e tag val)) ) (_putatt (entlast) "XYZ" "123") 1 1 Quote Link to comment Share on other sites More sharing options...
