phuynh Posted February 28, 2022 Posted February 28, 2022 (edited) Excel function drawing I-Beam section view based on known dimensions The focus is section area matching with the table value. Please noted that the I-Beam data collection in excel based on my knowledge and my use, I will not responsibility for any error or miss info's Phh I-Beam Table.xlsmFetching info... Option Explicit Sub AddIbeamToDwg() On Error Resume Next 'Connect to AutoCad application Dim acadApp As AcadApplication Set acadApp = GetObject(, "AutoCad.Application") If Err <> 0 Then Err.Clear MsgBox "Open the AutoCad application first and then execute!" Exit Sub End If 'Connect to AutoCad drawing document Dim acadDoc As AcadDocument Set acadDoc = acadApp.ActiveDocument 'Call excel to get data Dim excel As Object Set excel = GetObject(, "Excel.Application") Dim excelSheet As Object Set excelSheet = excel.ActiveWorkbook.Sheets(ActiveSheet.Name) 'Setup i-beam variables Dim ibStr As String Dim insertionPoint(0 To 2) As Double Dim height As Double Dim ibDepth As Double Dim ibWidth As Double Dim ibtw As Double Dim ibtf As Double Dim ibSc As Double Dim dblPi As Double dblPi = WorksheetFunction.Pi() Dim rw As Integer rw = ActiveCell.Row 'Check if row & 1st cell empty then stop If ActiveCell.Value = 0 Or excelSheet.Cells(rw, 1) = 0 Then MsgBox "No I-Beam data selected, please select row that contains data!" Exit Sub End If If excelSheet.Cells(rw, 1) Then ibStr = excelSheet.Cells(rw, 2) ibDepth = excelSheet.Cells(rw, 3) ibWidth = excelSheet.Cells(rw, 4) ibtw = excelSheet.Cells(rw, 5) ibtf = excelSheet.Cells(rw, 6) ibSc = excelSheet.Cells(rw, 7) End If Dim ibeamName As AcadText Dim plineObj As AcadLWPolyline Dim plineObj1 As AcadLWPolyline Dim ibRad As Double Dim ibRad1 As Double ibRad = 0 Dim points(0 To 37) As Double 'Create a temporary lwPolyline for calculating the area '4 corner area ratio = 3.65979236632549 points(0) = 0: points(1) = ibDepth points(2) = (ibWidth / 2): points(3) = ibDepth points(4) = (ibWidth / 2): points(5) = (ibDepth - ibtf) points(6) = (ibtw / 2 + ibRad): points(7) = (ibDepth - ibtf) points(8) = (ibtw / 2): points(9) = (ibDepth - (ibtf + ibRad)) points(10) = (ibtw / 2): points(11) = (ibtf + ibRad) points(12) = (ibtw / 2 + ibRad): points(13) = ibtf points(14) = (ibWidth / 2): points(15) = ibtf points(16) = (ibWidth / 2): points(17) = 0 points(18) = 0: points(19) = 0 points(20) = (ibWidth / 2) * (-1): points(21) = 0 points(22) = (ibWidth / 2) * (-1): points(23) = ibtf points(24) = (ibtw / 2 + ibRad) * (-1): points(25) = ibtf points(26) = (ibtw / 2) * (-1): points(27) = (ibtf + ibRad) points(28) = (ibtw / 2) * (-1): points(29) = (ibDepth - (ibtf + ibRad)) points(30) = ((ibtw / 2) + ibRad) * (-1): points(31) = (ibDepth - ibtf) points(32) = (ibWidth / 2) * (-1): points(33) = (ibDepth - ibtf) points(34) = (ibWidth / 2) * (-1): points(35) = ibDepth points(36) = 0: points(37) = ibDepth Set plineObj = acadDoc.ModelSpace.AddLightWeightPolyline(points) plineObj.Closed = True 'ibArea = plineObj.Area ibRad1 = VBA.Sqr(((ibSc - plineObj.Area) * 3.65979236632549) / dblPi) plineObj.Delete Dim vertices(0 To 37) As Double 'I-beam drawn after calculate radius base on lwPolyline above vertices(0) = 0: vertices(1) = ibDepth vertices(2) = (ibWidth / 2): vertices(3) = ibDepth vertices(4) = (ibWidth / 2): vertices(5) = (ibDepth - ibtf) vertices(6) = (ibtw / 2 + ibRad1): vertices(7) = (ibDepth - ibtf) vertices(8) = (ibtw / 2): vertices(9) = (ibDepth - (ibtf + ibRad1)) vertices(10) = (ibtw / 2): vertices(11) = (ibtf + ibRad1) vertices(12) = (ibtw / 2 + ibRad1): vertices(13) = ibtf vertices(14) = (ibWidth / 2): vertices(15) = ibtf vertices(16) = (ibWidth / 2): vertices(17) = 0 vertices(18) = 0: vertices(19) = 0 vertices(20) = (ibWidth / 2) * (-1): vertices(21) = 0 vertices(22) = (ibWidth / 2) * (-1): vertices(23) = ibtf vertices(24) = (ibtw / 2 + ibRad1) * (-1): vertices(25) = ibtf vertices(26) = (ibtw / 2) * (-1): vertices(27) = (ibtf + ibRad1) vertices(28) = (ibtw / 2) * (-1): vertices(29) = (ibDepth - (ibtf + ibRad1)) vertices(30) = ((ibtw / 2) + ibRad1) * (-1): vertices(31) = (ibDepth - ibtf) vertices(32) = (ibWidth / 2) * (-1): vertices(33) = (ibDepth - ibtf) vertices(34) = (ibWidth / 2) * (-1): vertices(35) = ibDepth vertices(36) = 0: vertices(37) = ibDepth 'Create a light weight Polyline object and draw in AutoCAD application Set plineObj1 = acadDoc.ModelSpace.AddLightWeightPolyline(vertices) plineObj1.Closed = True 'Add a bulge to segment 3 plineObj1.SetBulge 3, Tan(dblPi / 8) plineObj1.SetBulge 5, Tan(dblPi / 8) plineObj1.SetBulge 12, Tan(dblPi / 8) plineObj1.SetBulge 14, Tan(dblPi / 8) insertionPoint(0) = 0: insertionPoint(1) = -2: insertionPoint(2) = 0 height = 0.5 Set ibeamName = acadDoc.ModelSpace.AddText(ibStr, insertionPoint, height) ibeamName.Alignment = acAlignmentCenter ibeamName.Update plineObj1.Update End Sub Edited February 28, 2022 by phuynh Quote
BIGAL Posted March 1, 2022 Posted March 1, 2022 For me to hard, have a look at WiseysSteelShapes WiseysSteelShapes.zipFetching info... Quote
