Move blocks with certain attribute to position of Text having same content as attribute
Hi,
I have 4 block names:
AHS-1T, AHS-1TR, AHS-2T, AHS-2TR
They all have a text attribute called "TEE", with different values (e.g. N2096)
I have many of these 4 block types scattered, each having a distinct TEE attribute value,
on the other hand, I have a table where there are text objects having the same contents as the TEE attribute.
What I need is for the blocks to move to the position of the text which have the same content as the TEE value (eg block with Tee attribute "N2096" will move to the position of the text object which also reads "N2096".
Attached CAD Source and result for reference.
EDIT: just a tiny clarification, the block insertion point will match the X position of the text, but the Y position will be 148 units below the text. (although I can offset the Y position manually, so it's not a big deal). Thanks
Source.dwg Result.dwg
Edited by enthralled
Good trick with hiding TEXT entities...
But why are you lying with your Result.dwg... Your TEXT entites are on higher position than your placements of blocks...
So, I unhide them all...
Result-N.dwg Source-N.dwg
Don't know if you have multiple graphs so this will ask you to pick the "Row" to get the Y cords. x cords are pulled form the text. then its just a simple move command.
will display an error message if either multiple text are found or no text are found.
;; Move Blocks to graph location
(defun C:BlkMove (/ x y ss txt blk atts oTag)
  (setq y (cadr (getpoint "\nPick \"SPECIAL PIECES\" Row")))
  (prompt "\nSelect Blocks")
  (setvar 'cmdecho 0)
  (if (setq ss (ssget '((0 . "INSERT") (2 . "AHS-1T,AHS-1TR,AHS-2T,AHS-2TR") (66 . 1) (410 . "Model"))))
    (foreach blk (vl-remove-if 'listp (mapcar 'cadr (ssnamex SS)))
      (setq PT (cdr (assoc 10 (entget blk))))
      (setq atts (vlax-safearray->list (vlax-variant-value (vla-getattributes (vlax-ename->vla-object blk)))))
      (foreach tag atts
        (if (eq (vla-get-tagstring tag) "TEE")
            (setq oTag (vla-get-textstring tag))
            (if (setq txt (ssget "_X" (list '(0 . "*TEXT") (cons 1 oTag) '(410 . "Model"))))
              (if (eq (sslength txt) 1)
                  (setq x (car (cdr (assoc 10 (entget (ssname txt 0))))))
                  (vl-cmdf "_.Move" blk "" "_non" PT "_non" (list x y))
                (prompt (strcat "\nMultiple Text Found [" oTag "]"))
              (prompt (strcat "\nText not Found [" oTag "]"))
  (setvar 'cmdecho 1)
Just saw this :
Quote
Sorry for my bad insight and reaction...
  (setvar 'cmdecho 0)
      (foreach tag atts
  (setvar 'cmdecho 1)
Thanks for the help!
Also special thanks for allowing me to pick the row for the special pieces. This is so neat :)
