Help with a LISP or routine for multiple commands on many files
DanCoge
Good evening at all.
I am looking for some help to create a simple lisp that can perform some automatic operations on all dwg files contained in a specific directory.
The required operations are, in sequence:
- open file n.1;
- start of 3 cycles of the BURST lisp (both in the model and in the layouts);
- purge;
- save;
- close file n.1;
- open file n.2;
- start of 3 cycles of the BURST lisp (both in the model and in the layouts) ;
- purge;
- save;
- close file n.2;
...for all files contained in the folder.
BURST lisp is a explode "empowered".
Thanks at all for the support!
Daniele
Using accoreconsole would be the way to go there is example of modifying a directory. That is part 1.
The accoreconsole opens a dwg then runs a script, so the 2nd part is 3xburst purge save close in a script
https://through-the-interface.typepad.com/through_the_interface/2012/02/the-autocad-2013-core-console.html
  • Agree 1
