Redefining a dwg of Blocks into another dwg
rcb007
I know I can take individual dwgs and redefine them into the target dwg by either design center, blocks palette, or lisp routine.
Is there a method to take all blocks placed inside a UpdateMaster.dwg (Which has all the most update Blocks), then either redefine / update into the working dwg?
Thank you for any help.
http://www.lee-mac.com/steal.html
none tech way. save a copy of your updatemaster.dwg in the same folder as the drawing you want updated. delete everything out of updatedmaster but leave the block definitions. then go into your old drawing and cut all and paste it into the updatemaster.dwg. as long as the blocks have the same name & base point you should be good.  then use the steal command to move over everything else.
Edited by mhupp
  • Like 2
This is what I use ... it will require individual drawings per block ( code included ) placed somewhere in your search paths:
;; Redefine blocks with drawings found in search paths
(defun c:foo (/ file out)
  (setq out nil)
  (vlax-for x (vla-get-blocks (vla-get-activedocument (vlax-get-acad-object)))
    (or (wcmatch (vla-get-name x) "*|*,`**") (setq out (cons (vla-get-name x) out)))
  (setvar 'cmdecho 0)
  (foreach x out
    (if	(setq file (findfile (strcat x ".dwg")))
      (progn (command ".-INSERT" (strcat x "=" file) nil)
	     (and (ssget "_x" (list '(0 . "insert") (cons 2 x) '(66 . 1)))
		  (command "._attsync" "name" x)
  (setvar 'cmdecho 1)
;; Export all blocks in a drawing to a subfolder '_ExportedBlocks'
(defun c:exportblocks (/ x dir)
  (vl-mkdir (setq dir (strcat (getvar 'dwgprefix) "_ExportedBlocks\\")))
  (setvar 'filedia 0)
	(command "._-wblock" (strcat dir (vla-get-name x)) (vla-get-name x))
  (setvar 'filedia 1)
  (startapp "explorer" (strcat "/e," dir))
Edited by ronjonp
Thank you guys very much for your direction. Sounds like the only way to get this to work is by doing it individually.
If I have over 30 blocks that need to be redefined, then I will make it work.
Thanks again!
You can run lee-mac Steal from a program sense you can make a little lisp and steal multiple blocks in 1 go. So if you know the block names then its quick, I have done it. Just need to look again at the command sequence.
(if(not steal)(load "StealV1-6"))
(Steal "C:\\My Folder\\MyDrawing.dwg" '(("Blocks" "BLK1" "BLK2")) ) ; add more names
  • Agree 1
Nice.... Thank you for sharing. Saves alot of time!
