ntigner2469 Posted February 15, 2022 Share Posted February 15, 2022 Hello All, I have a simple lisp that does some very simple math just to save time. It simply askes for a garage floor elevation and then the number of steps leading to the finish slab of a house. It then takes that elevation, adds 0.67' per step and returns two text strings. One being the garage with the number of steps and it's elevation, and the slab with its calculated elevation. What I am trying to accomplish is for it to suppress any trailing zeros it might run into. If the garage elevation is 778.66' with 2 steps, then the finish floor elevation would be 778.66'+.67'+.67' = 780'. My lisp will always return 780.00. I am trying to find a way to make it suppress any trailing zeros, so it would return 780. Any help would be greatly appreciated. Code below. (Defun c:SLAB ( / Elev steps ffe ipnt) (setq name '("SLAB" "GARAGE")) (if (and (setq Elev (getdist "\nElevation: ")) (setq Steps (getint "\nNumber of steps: ")) (setq ffe ( + Elev (* 0.67 Steps))) ) (foreach itm (list (list (car name) (strcat (car name) "\\PFFE=" (rtos ffe 2 2)"\\PFND=" (rtos ffe 2 2))) (list (cadr name) (strcat (cadr name)"\\P" (itoa steps) " STEPS\\PG=" (rtos Elev 2 2))) ) (if (setq ipnt (getpoint (strcat "\nPick text insertion point for " (Car itm)))) (entmakex (list (cons 0 "MTEXT") (cons 100 "AcDbEntity") (cons 100 "AcDbMText") (cons 7 "CESO - Prop Arial") (cons 8 "C-BLDG-TEXT") (cons 40 2) (cons 10 ipnt) '(71 . 5) '(72 . 1) (cons 1 (cadr itm)) ) ) ) ) ) (princ) ) Quote Link to comment Share on other sites More sharing options...
ntigner2469 Posted February 15, 2022 Author Share Posted February 15, 2022 I was completely wrong. It's actually the opposite. I don't need it to suppress trailing zeros. I need it to add the trailing zeros. Right now it WOULD return 780 and they want it to return 780.00. Sorry for the confusion. Quote Link to comment Share on other sites More sharing options...
CyberAngel Posted February 15, 2022 Share Posted February 15, 2022 This is one of those weird AutoCAD quirks. Check the value of the DIMZIN system variable. That seems to be the only way to unsuppress trailing zeroes. Quote Link to comment Share on other sites More sharing options...
ronjonp Posted February 15, 2022 Share Posted February 15, 2022 http://www.lee-mac.com/consistentrtos.html 2 Quote Link to comment Share on other sites More sharing options...
