tuantrinhdp Posted February 13, 2022 Posted February 13, 2022 Hello everyone. I have a problem, please help. I want to calculate and write text area (square meter) when i click polygon, with choice: text height and decimal ( ex 0 or 0.0 or 0.00 or 0.000). test.dwg Quote
mhupp Posted February 13, 2022 Posted February 13, 2022 (edited) Should be what you are looking for. please only click in fully enclosed areas. Will ask you for text size and precision then ask to pick an area. it will input a text into the center of the area. if your picking inside weird shapes it could be outside. might have to rework the boundary command seems to be a bit different in BricsCAD. ;;----------------------------------------------------------------------------;; ;; Adds Area text (defun C:FOO (/ h x obj area LL UR MPT) (vl-load-com) (if (not (setq h (getreal (strcat "\nText Height ["(rtos (getvar 'textsize) 2 (getvar 'luprec))"]: ")))) (setq h (getvar 'textsize)) ) (setq x (getint "\n Prescision: ")) (while (setq pt (getpoint "\nPick Area: ")) (vl-cmdf "_.-Boundary" "A" "I" "No" "X" "_non" PT "") (setq obj (vlax-ename->vla-object (entlast))) (setq area (rtos (vla-get-area obj) 2 x)) (setq MPT (osnap (vlax-curve-getStartPoint obj) "gcen")) (entmake (list (cons 0 "TEXT") (cons 10 MPT) (cons 11 MPT) (cons 40 h) (cons 1 area) (cons 71 0) (cons 72 1) (cons 73 2) ) ) (vla-delete obj) ) (princ) ) Edited February 16, 2022 by mhupp updated code from: devitg, BIGAL 1 Quote
tuantrinhdp Posted February 13, 2022 Author Posted February 13, 2022 (edited) 48 minutes ago, mhupp said: Should be what you are looking for. please only click in fully enclosed areas. Will ask you for text size and precision then ask to pick an area. it will input a text into the center of the area. if your picking inside weird shapes it could be outside. might have to rework the boundary command seems to be a bit different in BricsCAD. ;;----------------------------------------------------------------------------;; ;; Adds Area text (defun C:FOO (/ h x a b area LL UR MPT) (vl-load-com) (setq h (getreal "\nText Height: ")) (setq x (getreal "\nPrecision: ")) (while (setq pt (getpoint "\nPick Area: ")) (vl-cmdf "_.-Boundary" "A" "I" "No" "X" "_non" PT "") (setq a (entlast)) (setq b (vlax-ename->vla-object a)) (setq area (rtos (vla-get-area b) 2 x)) (vla-getboundingbox b 'minpt 'maxpt) (setq LL (vlax-safearray->list minpt) UR (vlax-safearray->list maxpt) MPT (mapcar '/ (mapcar '+ LL UR) '(2 2 2)) ) (entmake (list (cons 0 "TEXT") (cons 10 MPT) (cons 11 MPT) (cons 40 h) (cons 1 area) (cons 71 0) (cons 72 1) (cons 73 2) ) ) (entdel a) ) (princ) ) Thank you, but i tried lisp didn't dislay a text into the center of the area. error: "Cannot invoke (command) from *error* without prior call to (*push-error-using-command*)" - with different drawing. and "bad argument type: fixnump: 2.0" ( when i input Precision) Edited February 13, 2022 by tuantrinhdp 1 Quote
mhupp Posted February 13, 2022 Posted February 13, 2022 When prompted with Precision input a whole number of how many decimal places you want. you can put 1 - 15 Quote
mhupp Posted February 13, 2022 Posted February 13, 2022 Seems the boundray comand in autocad is abit diffrent (vl-cmdf "_.-Boundary" "A" "I" "No" "X" "_non" PT "") change to (vl-cmdf "_.-boundary" "A" "I" "No" "" "" "_non" PT "") Quote
devitg Posted February 13, 2022 Posted February 13, 2022 @ tuantrinhdp please try this way I dare to modify MHUPP lisp . the text size default to actual TEXTSIZE I change GETINT , for precision, as it shall be an Integer and setq osmode to 0 And use -boundary , with no options ;;----------------------------------------------------------------------------;; ;; Adds Area text (defun C:Adds-Area-text (/ A AREA B H LL MAXPT MINPT MPT OSMODE PT TEXTSIZE UR X ) (vl-load-com) (setq textsize (getvar 'textsize)) (if (not(setq h (getreal "\nText Height: "))) (setq h textsize) ) (setq x (getint "\n Prescision")) (setq osmode (getvar 'osmode)) (setvar 'osmode 0) (while (setq pt (getpoint "\nPick Area: ")) ;(vl-cmdf "_.-Boundary" "A" "I" "No" "X" "_non" PT "") (vl-cmdf "_.-Boundary" PT "") (setq a (entlast)) (setq b (vlax-ename->vla-object a)) (vla-put-closed b :vlax-true) (setq area (rtos (vla-get-area b) 2 x)) (vla-getboundingbox b 'minpt 'maxpt) (setq LL (vlax-safearray->list minpt) UR (vlax-safearray->list maxpt) MPT (mapcar '/ (mapcar '+ LL UR) '(2 2 2)) ) (entmake (list (cons 0 "TEXT") (cons 10 MPT) (cons 11 MPT) (cons 40 h) (cons 1 area) (cons 71 0) (cons 72 1) (cons 73 2) ) ) (entdel a) );end while (setvar 'osmode osmode) (princ) ) ;|«Visual LISP© Format Options» (100 2 1 2 T " " 100 6 0 0 1 nil T nil T) ;*** DO NOT add text below the comment! ***|; adds-area-text.lsp to put text at center area.dwg 1 1 Quote
mhupp Posted February 13, 2022 Posted February 13, 2022 (edited) This goes for anyone. please feel free to edit anything i post. I often come back and edit things after thinking about it for awhile. Nice to see whats its going to be if you just hit enter. (if (not(setq h (getreal (strcat "\nText Height ["(rtos (getvar 'textsize) 2 (getvar 'luprec)) "]: ")))) (setq h textsize) ) Text Height [0.2000]: No need to change osmode just put "_non" in front of pt. (vl-cmdf "_.-Boundary" "_non" PT "") This could give the wrong area if their is an island tho. Edited February 19, 2022 by mhupp updated code 2 Quote
tuantrinhdp Posted February 13, 2022 Author Posted February 13, 2022 5 hours ago, devitg said: @ tuantrinhdp please try this way I dare to modify MHUPP lisp . the text size default to actual TEXTSIZE I change GETINT , for precision, as it shall be an Integer and setq osmode to 0 And use -boundary , with no options ;;----------------------------------------------------------------------------;; ;; Adds Area text (defun C:Adds-Area-text (/ A AREA B H LL MAXPT MINPT MPT OSMODE PT TEXTSIZE UR X ) (vl-load-com) (setq textsize (getvar 'textsize)) (if (not(setq h (getreal "\nText Height: "))) (setq h textsize) ) (setq x (getint "\n Prescision")) (setq osmode (getvar 'osmode)) (setvar 'osmode 0) (while (setq pt (getpoint "\nPick Area: ")) ;(vl-cmdf "_.-Boundary" "A" "I" "No" "X" "_non" PT "") (vl-cmdf "_.-Boundary" PT "") (setq a (entlast)) (setq b (vlax-ename->vla-object a)) (vla-put-closed b :vlax-true) (setq area (rtos (vla-get-area b) 2 x)) (vla-getboundingbox b 'minpt 'maxpt) (setq LL (vlax-safearray->list minpt) UR (vlax-safearray->list maxpt) MPT (mapcar '/ (mapcar '+ LL UR) '(2 2 2)) ) (entmake (list (cons 0 "TEXT") (cons 10 MPT) (cons 11 MPT) (cons 40 h) (cons 1 area) (cons 71 0) (cons 72 1) (cons 73 2) ) ) (entdel a) );end while (setvar 'osmode osmode) (princ) ) ;|«Visual LISP© Format Options» (100 2 1 2 T " " 100 6 0 0 1 nil T nil T) ;*** DO NOT add text below the comment! ***|; adds-area-text.lsp 1.4 kB · 0 downloads to put text at center area.dwg 53.35 kB · 0 downloads thank you so much. Quote
BIGAL Posted February 16, 2022 Posted February 16, 2022 Guys check out GCEN this is geometric centre of a pline, Bricscad & Acad. (setq pt (osnap (vlax-curve-getStartPoint (vlax-ename->vla-object (entlast))) "gcen")) 1 1 Quote
viviancarvalho Posted March 13, 2022 Posted March 13, 2022 Check out this link. http://www.lee-mac.com/areastofield.html Thanks to Lee-mac Quote
BIGAL Posted March 14, 2022 Posted March 14, 2022 mhupp use bpoly rather than boundary Like you polygon is different in Bricscad, I uses a check for acadver and use wcmatch so basically do like 3 lines instead of 1. ACADVER = "22.0 BricsCAD" (read only) 1 Quote
karsen Posted April 5, 2022 Posted April 5, 2022 (edited) On 3/13/2022 at 10:15 AM, viviancarvalho said: Check out this link. http://www.lee-mac.com/areastofield.html Thanks to Lee-mac how can I change unit? and add the text "ha" after the number I want have hectares --> 0.0001ha Edited April 5, 2022 by karsen Quote
devitg Posted April 5, 2022 Posted April 5, 2022 @karsen, you can use the FIELD command , and arrange to yours need. Quote
Steven P Posted April 5, 2022 Posted April 5, 2022 Adding a suffix I think look for the lines: (setq str (strcat "%<\\AcObjProp Object(%<\\_ObjId " (LM:ObjectID (vlax-ename->vla-object (ssname sel 0))) ">%).Area \\f \"" fmt "\">%" ) ) and (setq str (strcat "%<\\AcExpr " (apply 'strcat (reverse (cdr (reverse lst)))) " \\f \"" fmt "\">%" ) ) and before the closing brackets for (strcat.... add your suffix text ("ha"), something like .... " \\f \"" fmt "\">%" " ha" ) ) That will give you the area as a field and then the ha as text after it. Not sure but the units will depends on the units your drawing is using. Lee Mac has a thing here, format codes http://www.lee-mac.com/fieldformat.html so if you set up the formatting for one of the fields created above as you want and use this, then you can change this line: (setq fmt "%lu6%qf1") ;; Field Formatting and put in the code that fieldformat gives you (I think) 1 Quote
