Philipp Posted February 23, 2022 Author Share Posted February 23, 2022 If I change that, it will not find a block to select, I tried the following but it changes all elements again: (defun err-ubc (s) ; If an error (such as CTRL-C) occurs ; while this command is active... (if (/= s "Function cancelled") (princ (strcat "\nError: " s)) ) (setq *error* olderr) ; Restore old *error* handler (princ) );err-ubc (DEFUN C:BBL (/ *error* BLK CBL CBL2 C ACL ALY NLY NCL) (defun *error* (s) ; Localized *error* for if an error (such as CTRL-C) occurs ; while this command is active... (if (/= s "Function cancelled") (princ (strcat "\nError: " s)) ) (princ) );*error* (initget "?") (while (or (eq (setq C (getint "\nEnter new color number/<?>: ")) "?") (null C) (> C 256) (< C 0) );or (textscr) (princ "\n ") (princ "\n Color number | Standard meaning ") (princ "\n ________________|____________________") (princ "\n | ") (princ "\n 0 | <BYBLOCK> ") (princ "\n 1 | Red ") (princ "\n 2 | Yellow ") (princ "\n 3 | Green ") (princ "\n 4 | Cyan ") (princ "\n 5 | Blue ") (princ "\n 6 | Magenta ") (princ "\n 7 | White ") (princ "\n 8...255 | -Varies- ") (princ "\n 256 | <BYLAYER> ") (princ "\n \n\n\n") (initget "?") );while (PROMPT "\nPick blocks to update. ") (SETQ SS (SSGET '((0 . "INSERT")))) (SETQ K 0) (WHILE (< K (SSLENGTH SS)) (setq CBL (tblsearch "BLOCK" (CDR (ASSOC 2 (ENTGET (SETQ BLK (SSNAME SS K))))))) (SETQ CBL2 (CDR (ASSOC -2 CBL))) (WHILE (BOUNDP 'CBL2) (SETQ EE (ENTGET CBL2)) ;Update layer value (SETQ NCL (CONS 62 C)) (SETQ ACL (ASSOC 62 EE)) (IF (= ACL nil) (SETQ NEWE (APPEND EE (LIST NCL))) (SETQ NEWE (SUBST NCL ACL EE)) );if (or(=(cdr(ASSOC 8 EE))(2 . "ET_SYMB_BLOCK"))(ENTMOD NEWE)) (SETQ CBL2 (ENTNEXT CBL2)) );end while (ENTUPD BLK) (SETQ K (1+ K)) );end while (setq *error* olderr) (princ) );end BBL Quote Link to comment Share on other sites More sharing options...
ronjonp Posted February 23, 2022 Share Posted February 23, 2022 Are you using dynamic blocks? Quote Link to comment Share on other sites More sharing options...
Philipp Posted February 25, 2022 Author Share Posted February 25, 2022 yes and no, the program from tombu works in some way for my configuration, except for it does quite the opposite I want it and affects all but not a specific layer. Unfortunatly I cant tell the programm to affect 1 specific layer, or write it the other way around to not! affect more than one layer. Quote Link to comment Share on other sites More sharing options...
marko_ribar Posted February 25, 2022 Share Posted February 25, 2022 (edited) (defun c:bbl ( / *error* ss k blk cbl cbl2 ee c acl aly nly ncl ) (defun *error* ( s ) ; localized *error* for if an error (such as ctrl-c) occurs ; while this command is active... (if (/= s "function cancelled") (princ (strcat "\nError: " s)) ) (princ) ) ; *error* (while (or (textscr) (princ "\n ") (princ "\n color number | standard meaning ") (princ "\n ________________|____________________") (princ "\n | ") (princ "\n 0 | <byblock> ") (princ "\n 1 | red ") (princ "\n 2 | yellow ") (princ "\n 3 | green ") (princ "\n 4 | cyan ") (princ "\n 5 | blue ") (princ "\n 6 | magenta ") (princ "\n 7 | white ") (princ "\n 8...255 | -varies- ") (princ "\n 256 | <bylayer> ") (princ "\n \n\n\n") (progn (initget "?") (setq c (getint "\nEnter new color number <?> : ")) nil) (or (not c) (= c "?")) (and c (not (<= 0 c 256))) ) ; or ) ; while (prompt "\nSelect blocks to update...") (if (setq ss (ssget "_:L" '((0 . "INSERT") (2 . "ET_SYMB_BLOCK")))) (progn (setq k 0) (while (< k (sslength ss)) (setq cbl (tblsearch "BLOCK" (cdr (assoc 2 (entget (setq blk (ssname ss k))))))) (setq cbl2 (cdr (assoc -2 cbl))) (while (boundp 'cbl2) (setq ee (entget cbl2)) ; update layer value (setq ncl (cons 62 c)) (setq acl (assoc 62 ee)) (if acl (setq newe (subst ncl acl ee)) (setq newe (append ee (list ncl))) ) ; if ;| (or (wcmatch (cdr (assoc 8 ee)) (strcat "ET_SYMB_GREY" "," "ET_ATTR_ABMESS" "," "ET_ATTR_BEZ" "," "ET_ATTR_LEIST" "," "ET_ATTR_LV" "," "ET_ATTR_SCHALT" "," "ET_ATTR_SCHUTZ" "," "ET_ATTR_STROM" "," "ET_ATTR_TUER" "," "ET_ATTR_TYP" "," "ET_ATTR_VERT" ) ) (entmod newe) ) |; ;;; ^^^ Above is exactly what you want ^^^, but I prefer this what I wrote below : vvv (study "wcmatch" function - it can serve to very beneficial appliance) vvv ;;; (or (wcmatch (cdr (assoc 8 ee)) "ET_SYMB_*,ET_ATTR_*") (entmod newe)) (setq cbl2 (entnext cbl2)) ) ; end while (entupd blk) (setq k (1+ k)) ) ; end while ) ; end progn (prompt "\nEmpty sel. set... Nothing selected...") ) ; end if (ss) (princ) ) ; end bbl Edited February 25, 2022 by marko_ribar Quote Link to comment Share on other sites More sharing options...
Philipp Posted February 26, 2022 Author Share Posted February 26, 2022 17 hours ago, marko_ribar said: (defun c:bbl ( / *error* ss k blk cbl cbl2 ee c acl aly nly ncl ) (defun *error* ( s ) ; localized *error* for if an error (such as ctrl-c) occurs ; while this command is active... (if (/= s "function cancelled") (princ (strcat "\nError: " s)) ) (princ) ) ; *error* (while (or (textscr) (princ "\n ") (princ "\n color number | standard meaning ") (princ "\n ________________|____________________") (princ "\n | ") (princ "\n 0 | <byblock> ") (princ "\n 1 | red ") (princ "\n 2 | yellow ") (princ "\n 3 | green ") (princ "\n 4 | cyan ") (princ "\n 5 | blue ") (princ "\n 6 | magenta ") (princ "\n 7 | white ") (princ "\n 8...255 | -varies- ") (princ "\n 256 | <bylayer> ") (princ "\n \n\n\n") (progn (initget "?") (setq c (getint "\nEnter new color number <?> : ")) nil) (or (not c) (= c "?")) (and c (not (<= 0 c 256))) ) ; or ) ; while (prompt "\nSelect blocks to update...") (if (setq ss (ssget "_:L" '((0 . "INSERT") (2 . "ET_SYMB_BLOCK")))) (progn (setq k 0) (while (< k (sslength ss)) (setq cbl (tblsearch "BLOCK" (cdr (assoc 2 (entget (setq blk (ssname ss k))))))) (setq cbl2 (cdr (assoc -2 cbl))) (while (boundp 'cbl2) (setq ee (entget cbl2)) ; update layer value (setq ncl (cons 62 c)) (setq acl (assoc 62 ee)) (if acl (setq newe (subst ncl acl ee)) (setq newe (append ee (list ncl))) ) ; if ;| (or (wcmatch (cdr (assoc 8 ee)) (strcat "ET_SYMB_GREY" "," "ET_ATTR_ABMESS" "," "ET_ATTR_BEZ" "," "ET_ATTR_LEIST" "," "ET_ATTR_LV" "," "ET_ATTR_SCHALT" "," "ET_ATTR_SCHUTZ" "," "ET_ATTR_STROM" "," "ET_ATTR_TUER" "," "ET_ATTR_TYP" "," "ET_ATTR_VERT" ) ) (entmod newe) ) |; ;;; ^^^ Above is exactly what you want ^^^, but I prefer this what I wrote below : vvv (study "wcmatch" function - it can serve to very beneficial appliance) vvv ;;; (or (wcmatch (cdr (assoc 8 ee)) "ET_SYMB_*,ET_ATTR_*") (entmod newe)) (setq cbl2 (entnext cbl2)) ) ; end while (entupd blk) (setq k (1+ k)) ) ; end while ) ; end progn (prompt "\nEmpty sel. set... Nothing selected...") ) ; end if (ss) (princ) ) ; end bbl Thanks, but it does not select the block again, like in every code with the line: (if (setq ss (ssget "_:L" '((0 . "INSERT") (2 . "ET_SYMB_BLOCK")))) maybe another way around that would be easier to archieve would be a program that does this: select block(s) search for colour *select colour 0-256 (in my example: green) change to colour *select colour 0-256 (in my example: byblock) Quote Link to comment Share on other sites More sharing options...
