lrm Posted February 18, 2022 Share Posted February 18, 2022 I was wondering if NFT's (Non-fungible Tokens) might be used. It might not be practical in this application but in theory would it work? 1 Quote Link to comment Share on other sites More sharing options...
BIGAL Posted February 18, 2022 Share Posted February 18, 2022 (edited) Ok so had a think and ended up with this you need the where are the lisps d:\\temp, where is the licence.lsp and a out put directory \\temp\\compile. Change to suit your pc. its rough as its only used to make new lisps yes can be way better with more bells and whistles. (setq lspdir (vl-directory-files "d:\\temp" "*.lsp")) (setq fo (open "d:\\temp\\licfiles.bat" "w")) (foreach lsp lspdir (write-line (strcat "copy d:\\alan\\lisp\\licence.lsp+" "\"d:\\temp\\" lsp "\"" " " "\"d:\\temp\\compile\\" lsp "\"") fo ) ) (close fo) (command "shell" "d:\\temp\\licfiles.bat") Edited February 19, 2022 by BIGAL Quote Link to comment Share on other sites More sharing options...
mhupp Posted February 19, 2022 Share Posted February 19, 2022 1 hour ago, lrm said: I was wondering if NFT's (Non-fungible Tokens) might be used. It might not be practical in this application but in theory would it work? tho this is probably an actual use for nft's. Quote Link to comment Share on other sites More sharing options...
Steven P Posted February 19, 2022 Share Posted February 19, 2022 11 hours ago, lrm said: I was wondering if NFT's (Non-fungible Tokens) might be used. It might not be practical in this application but in theory would it work? Not something I have come across before really, but if you apply one of these to a LISP file will that stop another user opening the file and yet allow the originators CAD to run the LISP? Quote Link to comment Share on other sites More sharing options...
BIGAL Posted February 20, 2022 Share Posted February 20, 2022 An extra step for above code updated will make fas files. Quote Link to comment Share on other sites More sharing options...
viviancarvalho Posted March 13, 2022 Share Posted March 13, 2022 check out this thread for a similar kind of question http://www.cadtutor.net/forum/showthread.php?54624-Time-bound-Lisp Quote Link to comment Share on other sites More sharing options...
mohammadreza Posted August 12, 2023 Share Posted August 12, 2023 On 2/13/2022 at 12:06 PM, Kajanthan said: Very Strongest Protected lisp code funny result (eq "DD:13:EF:3D:95:AC" ret) ;; This is your Pc MAC (eq "BFEBFBFF040908EA" serx) ;; This is your Processor Id Licence.lsp 2.44 kB · 80 downloads hi, thanks for your solution. Can i ask how it work? Quote Link to comment Share on other sites More sharing options...
BIGAL Posted August 12, 2023 Share Posted August 12, 2023 (edited) You can get hard disk Id, Mac address, or processor ID as suggested. Some hard disk code examples (setq ser (vla-get-Serialnumber (vlax-invoke (vlax-create-object "Scripting.FileSystemObject") 'getdrive "c:"))) ; drive type 1 is a usb 2 hard disk (defun UsbDriveSerialNumber ( / fso dr) (setq fso (vlax-create-object "Scripting.FileSystemObject")) (vlax-for d (vlax-get fso 'Drives) (if (= (Vlax-get d 'DriveType) 2) (setq dr (cons (list (vla-get-path d) (vla-get-SerialNumber d)) dr) ) ) ) (vlax-release-object fso) (reverse dr) ) (UsbDriveSerialNumber) (vlax-for d (vlax-get fso 'Drives) (princ (Vlax-get d 'DriveType) ) ) "Can i ask how it work?" Did you look at the lisp posted ? Edited August 12, 2023 by BIGAL 1 Quote Link to comment Share on other sites More sharing options...
