I was wondering if NFT's (Non-fungible Tokens) might be used. It might not be practical in this application but in theory would it work?
  • Funny 1
Ok so had a think and ended up with this you need the where are the lisps d:\\temp, where is the licence.lsp and a out put directory \\temp\\compile. Change to suit your pc.
its rough as its only used to make new lisps yes can be way better with more bells and whistles.
(setq lspdir (vl-directory-files "d:\\temp" "*.lsp"))
(setq fo (open "d:\\temp\\licfiles.bat" "w"))
(foreach lsp lspdir
(write-line (strcat "copy d:\\alan\\lisp\\licence.lsp+" "\"d:\\temp\\" lsp "\"" " " "\"d:\\temp\\compile\\" lsp "\"") fo )
(close fo)
(command "shell" "d:\\temp\\licfiles.bat")
Edited by BIGAL
tho this is probably an actual use for nft's.
Not something I have come across before really, but if you apply one of these to a LISP file will that stop another user opening the file and yet allow the originators CAD to run the LISP?
  • 3 weeks later...
  • 1 year later...
On 2/13/2022 at 12:06 PM, Kajanthan said:
Very Strongest Protected lisp code
funny result
        (eq "DD:13:EF:3D:95:AC" ret) ;; This is your Pc MAC
        (eq "BFEBFBFF040908EA" serx) ;; This is your Processor Id
hi, thanks for your solution.
Can i ask how it work?
You can get hard disk Id, Mac address, or processor ID as suggested. Some hard disk code examples
(setq ser (vla-get-Serialnumber (vlax-invoke (vlax-create-object "Scripting.FileSystemObject") 'getdrive "c:")))
; drive type 1 is a usb 2 hard disk
(defun UsbDriveSerialNumber ( / fso dr)
  (setq fso (vlax-create-object "Scripting.FileSystemObject"))
  (vlax-for d (vlax-get fso 'Drives)
    (if
	  (= (Vlax-get  d 'DriveType) 2)
      (setq dr (cons (list (vla-get-path d) (vla-get-SerialNumber d)) dr)
  (vlax-release-object fso)
  (reverse dr)
(UsbDriveSerialNumber)
	  (princ (Vlax-get  d 'DriveType) )
"Can i ask how it work?" Did you look at the lisp posted ?
Edited by BIGAL
